Thread: SWG cell with check valve
    I have a check valve that's connected to my cell (Zodiac LM2) it's in the vertical position which I installed based on the showroom where I had bought the pool but the manual says not to do this and I am curious as to why? I'm assuming the valve won't shut properly?
    22,541
    Re: SWG cell with check valve
    The check valve is in the vertical position or the cell?
    The reason not to put it in the vertical position is due to the possible build up of explosive gas.
    Can you post a pic?
    I do have pics but I have to resize them as I took them using my phone. Well that would explain why I'm on my 3rd cell.....I installed it just like they did in the showroom where I bought the pool. When I pick up the cell which they are covering I'm going to mention it to them.....UNBELIEVABLE
    Jul 2011
    Austin, Texas
    78
    Most pool stores are staffed by kids that don't have pools. You already have more knowledge than they do.
    30K IG, Plaster with spillover spa, 9 ft deep end with spring base diving board
    48sqft DE Filter, 3HP VS motor, Hayward SPII, Raypak RP2100 Propane heater
    AutoPilot Pool Pilot Digital with SC-60 and pump relay (220v)
    Polaris 280. Pentiar Booster Pump, TF-100 Test Kit, Speed Stir
    Austin, Texas (It's hot)
    I guess I should of mentioned that but yes the cell is horizontal but the one way check valve is vertical.
    Ft Lauderdale, Florida
    1,455
    It's most likely to prevent the chlorine from backflowing to equipment upstream from the cell, so as to avoid any corrosion damage. I'm guessing it's a gravity check valve, rather than a spring.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
