Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: New Pool build in Austin, Tx
    We finally broke ground last week on the construction of our pool.
    Here are the specs.
    Dimensions: 38 ft x 21.5 ft x 14.5 ft
    Perimeter: 102 ft.
    Surface Area: 590 sq ft
    Approximate Volume: 19,600 gallons
    Depth: 4.0 ft to 4.75ft to 4.0 ft
    Steps: One set per plan with 75 sq ft lounge
    Benches / swim outs: 20 linear ft
    Coping: Oklahoma Flagstone (Will be sealed)
    Other: Raised beams with 2 ft scupper, and Fountain in lounge area.
    Other: Volleyball and umbrella sleeves
    EQUIPMENT
    Pumps: (1) Pentair 011013 VS 3050 Intelliflo
    Filter: (1) Pentair FNSP60 FNS Plus
    Water Treatment: Pentair IC40
    Heater: Pentair 125K 240V Ultra Temp 120 (This has been changed to a model that also cools)
    Pool Cleaner: Pentair Letro booster pump w/ Pentair legend LL505G (grey)
    Skimmers: Two
    Lights: 4 - Pentair Globrite Shallow Water LED Lights
    Drains Two anti vortex in pool
    Controls: Pentair Easy Touch with wireless controls.
    Equipment Pad: All equipment is set on a concrete pad.
    Maintenance Equipment: Wall brush, leaf bagger, telescoping pole
    Start-Up Chemicals: Included
    STEEL
    1/2 Rebar tied on 10 Centers with a four bar beam and additional bars at all high stress areas if required.
    GUNITE
    Dry Gunite per industry standard, Water and Quality Controlled at Job Site
    Minimum floor and Wall Thickness of 8-10 (12 when out of ground)
    PLUMBING
    All Plumbing with schedule 40 PVC 2 plumbing to skimmers, main drains.
    Separate main drain and skimmer lines with independent valves.
    Independently plumbed suction lines for water feature
    Two Pool Main Drains (anti-vortex type))
    Skimmers (qty. 2) with equalizer intake
    ELECTRIC
    Bonding By Electric Code (#8 copper wire)
    Hook Up of Under Water Lights, Timers and Pool Pump
    Includes all circuit Breakers, GFI, Etc.
    Freeze control
    220 power line to portable spa per code
    (2) 110 outlets and service for lights to shade structure and counter
    DECKS
    389 sq ft of reinforced concrete deck with approved Sundeck finish.
    469 sq ft existing concrete to receive matching Sundeck finish
    100 sq ft fire pit area with flagstone and gravel
    PLASTER
    Wet Edge Satin Matrix Jet Black
    SHADE STRUCTURE
    8 ft x 14 ft Cedar shade structure with metal roof per conceptual design
    Power for lights included. Light fixtures to be selected and supplied by owner.
    Kitchen
    7 ft x 2 ft counter, 36 inches height with level on granite top. Structure shall be constructed with CMU block with approved stone veneer. Counter to have 110 outlet and stainless steel door for storage inside. Door supplied by customer
    20k gallon AG pebble pool in Austin, Texas. All Pentair equipment (DE, IC40 SWCG, heatpump, variable speed pump with aux pump for the cleaner). Built in 4/2013.
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Re: New Pool build in Austin, Tx
    Beautiful well thought out design..!! Any reason why you didn't include a spa with the pull? I'm guessing you live where you won't keep the pool open year around?
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Thanks!. We decided to go with an after market spa. They don't look as nice but they are so much more comfortable.
    Sunny SoCal
    592
    Quote Originally Posted by sfawley
    They are pretty cool. We see them at the fair every year and can't believe how many features they have. Disco lights, cup holders, TV's, stereos, messagers... not mention self containment of all the equipment.
    Good luck with your build.. we are about 1-1/2 weeks away from the finish on ours!
    I knew we had rock under us but I had no idea it was going to be like this!
    And more rock...
    Casey's Avatar
    SW PA
    10,461
    Omg! Do you have any dirt?!!!
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    I do feel your pain.... We dug out rock then had to buy tons of the stuff to fill in to create a back yard. Beautiful design!
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Aug 2007
    near the swamp
    806
    time to break out the dynomite
    They finished the steel today. Plumbing starts in the morning. Progress!
    JimboAZ's Avatar
    Oct 2012
    Maricopa, AZ
    103
    Wow, that design looks great!
    --22k gallon pool/spa, IG, pebble w/ glass beads/abalone, all tile spa w/ stacked stone and spillway, 30 sf waterfall, 3 telescopic fountains, EZ Touch 8
    --Pentair VS3050, Whisperflo waterfall pump, Clean & Clear 520 cartridge filter, Intellibrite 5G LED lights, Ozone, Q360 in-floor cleaning, 400k btu heater
    --100 perim ft pool, 25 perim ft spa, Depth 3.5' to 7', 405 sq ft travertine decking, TF100 test kit
    --Time Lapse Video of our Pool Build ---- Our Pool Build Thread
    Finally moving along again after a bit of a delay due to getting the city out here to do the grounding inspection.
    They shot the gunite yesterday. The pool is finally starting to take shape!
    Love it! Love your huge sunshelf! That is the only thing I am not competely happy with so far is I should have done a bigger sunshelf! I didn't want to take away from my pool area, but now seeing the pool, it is so big I had plenty of room! Oh well, still love it.. but love that shelf! Going to be so nice!
    Finished the rock and tile work today. Decking starts on Monday. Just over two weeks left until they can add the pebble and then the water!
    Plaster is done. Adding water!
    Looks great. I love the look of the plaster. I wanted to go darker, but the boss did not. Can't wait to see the final pictures. I would think about having them change your jets out to a black instead of while.
    McKinney, TX
    Pool build in progress, 14.8K gallons, OK flagstone copping (sealed), IG Gunite/Pebblesheen (Blue Granite), Pentair intelliflow 3050 vs - svrs, Pentair IC20 Salt-Gen, 60 sq ft Pentair DE filter, 400k BTU Pentair (NG) heater, Polaris 280 with Booster, Dual Time Clocks with freeze protect feature, Pool (1) 500w (1) 100W Spa (1) 100w lights, (2) Skimmers, 4 Pool Returns, 6 Spa Jets, water features incl (3) 12 scuppers on 12 x 31 raised beam, (2) Gushers on tanning ledge, and double cut spa spillway. controlled by easytouch 8
    http://www.troublefreepool.com/under...t56120-40.html
    Guest
    Looks awesome!! Would you mind telling me what the distance is between the house and the pool?
    Apr 2012
    Klein Tejas
    249
    I'm sure you'll be giving that heat pump a work out!
    You don't have small children do you? I find dark plaster, while cool looking, very hard to see into.
    Good luck!
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
  20. Back To Top    #20
    Beautiful pool!!
