Thread: Polaris 360/380 Relief
    crusemm's Avatar
    Sep 2011
    North Texas
    31
    Recently had some issues with my polaris pool robot. Not sure of the model, either a 360 or 380. Had a low pressure condition and thought it might be the relief valve so I replaced it. turns out I had a leaf stuck in the turbine/blocking the jet. once I got the leaf cleaned out, started up the pool cleaner, and my new relief is blowing water like crazy, which it did not do before. So, I guess I got the wrong relief? Anyone know what the model/part number of the higher pressure relief valve is? Thanks
    21,000 gal In Ground Plaster pool; Nautilus FNS 60 DE filter; WhisperFlo WFE-6 pump; Polaris booster pump and pool cleaner;Rainbow Lifegard HiFlow Chlorine Feeder (not in use); Purex Triton pool light;Hatteras spa light; Intermatic model PF122T Freeze Sentry pump controller; Sta-Rite U-3 Skimmer.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Polaris 360/380 Relief
    crusemm:
    The P/N for the Pressure Relief Valve on the Polaris 360 is 9-100-3009 according to my owner's manual. For the Polaris 380, the P/N is 9-100-9002.
    crusemm's Avatar
    Sep 2011
    North Texas
    31
    Well, I I ordered one of each. I I think I got the wrong one last time, so I will try both and see which works.
