Thread: what is the realibility of pump vs motor failure!
    Apr 2012
    chandler az
    65
    I have a motor that died, , working with my warranty company and that refuses to replace motor with multiple speed motor.
    Based the pump portion did not fail. single speed motor is their solution. What is your experience with a pump that has motor failure and not the pump portion.
    I just feel that a 8 year old pump is not worthly of motor replacement only.
    Thanks in advance for your experiences and insight.
    dirtfrmr aka a golfer who is always in the dirt
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: what is the realibility of pump vs motor failure!
    Pump wet ends can usually outlast the motor several times over. About the only thing that can go wrong is the pump housing develops a crack and starts to leak. Everything else can usually be replaced.
    You might ask them if you could pay the difference for a two speed motor. Also, check your local regulations. More states are requiring at least a two speed replacement but it may not be for just the motor.
    Mark
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by mas985
    +1.
    I've got 2 pumps, (one a Hayward SuperPump, the other, a Polaris booster pump) each more than 20-years-old. Replaced one cracked veloute; 2, maybe 3 impellers; some seals. Pumps work fine, last a long time.
    Motors, not so much. I've had the pumps into the shop numerous times for repair or replacement.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
