Thread: Pool spa service newsletter
    Curious if somebody here wrote an article for this pool and spa newsletter. I was at the warehouse casually flipping through the newsletter when i saw what looked like the exact same FC/CYA chart i have seen on this forum. It had minimum fc, target fc, and shock fc levels for cya levels from 20 to 100. I have only seen that chart on this forum so i was curious
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Pool spa service newsletter
    Do you have a link to it so we can see if we can figure out where it came from? There are a few sites that have copied the FC/CYA chart and some refer to this site while others don't. Don't forget that the original FC/CYA chart came from Ben Powell at The PoolForum.
    Sep 2012
    Cypress, TX
    63
    I hope it's okay to post links. My apologies if not.
    (Admittedly not the newsletter that you reference but I do like finding stuff that references TFP)
    Here is the one that I keep printed out and in my binder. It references this site.
    http://www.anotherperfectpoolnews.com/w ... -Ratio.pdf
    18,000 Gallon IG, Pebble Sheen, Quartzite coping
    Pentair 420 Cartridge Filter, 2HP Silencer, 400,000 BTU Heater, Platinum Legend Cleaner
    2x IntelliFlo VS pumps - Screenlogic Interface - Stenner 45MPHP10 15 Gal Bleach Injection
    TF100 + PoolCalculator + This Site!
    Feb 2008
    Denton, TX
    5,061
    Most likely, it was done by someone who was/is a member here at TFP! Good to see that it has been cited as to the source.
    yeah i cant find the article anywhere online, but it was something called the pool and spa newsletter. Ill have to see if it is still laying around the store tommorow
