Thread: water outside edge of pool
    Hi,
    I have a pool under construction. They shot the shotcrete 9 days ago. We had several days of heavy rain since, but dry for the past 4 days. I have an area outside the pool where I'm seeing water collect. I have a call into my contractor to come out and take a look. He said it probably was water just seeping up ... being pushed up by the pool. I have read this elsewhere on the internet as well, but I'm concerned that we might have a leak in the pipes. He had me look at a pressure gauge that is connected and it does show 35 (psi ... I think). Should I be concerned at all?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: water outside edge of pool
    Welcome to TFP!
    If your pipes are holding pressure, you have nothing to worry about there! Water won't be "pushed up by the pool", it's probably just groundwater seeping up.
    38,301
    Although, 35 psi is a pretty high pressure. How large is your pump, what size/model filter? Any other details that could explain that?
    If the water was coming from the pool enough to make the ground that wet, I would think you would have noticed the pool water level go down over the last 4 days. There is always the bucket method to see if your pool has a leak.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, kmclaurin
    Assuming your pool isn't plastered yet, then I assume that the pb left the pipes pressurized to look for leaks? Is the pool full and pump running or did they leave the pipes sealed in the process of performing a leak test?
    38,301
    Ugh ... apparently my previous post makes no sense since I did not pay attention
    Thanks for the replies. I think I'm OK. The water level that I'm seeing at the spot outside the pool has "stableized" and the pressure is consistant. I don't have a pump installed yet. They just have a gauge attached to some of the plumbing at the side of my house.
