Does anyone else have problems getting the Pentair EasyTouch to do what they want to do?
I think it might be my terminology vs. Pentair's terminology and definitions. I might just have a brain cramp since I have quite a bit of electrical experience.
My main schedule (8am to 7pm) works as intended (IntelliFlo pump works at correct rpm, pool/spa valves are set correctly, IntelliChlor works, IntellipH works.
I created another schedule outside the original schedule (3am to 4am) and the IntelliChlor works but the IntellipH does not function.
I created a pump high speed and the intelliChlor works and the IntellipH works.
I created a pump low speed (high enough rpm to make the IntellipH flow switch turn on then added 300 rpm for good measure to be sure it stayed on) and the IntelliChlor works but the IntellipH will not function.
I have noticed that it looks like if you press anything then schedules do not work for 24 hours? Why, I do not know, what logic this is?
It appears that this EasyTouch is a very powerful piece of equipment but contrary to human logic and desires.
Future Desires: I also wanted to add a new schedule for cleaning with a Pentair Legend II (uses existing pool pump without booster pump).
Is there some secret instruction manual somewhere that is written with examples? I have not been able to make heads or tails of the manual that came with the EasyTouch.
How do you make things happen (program the EasyTouch) like the owner wants it too? This unit should make a person if everything worked as desired.
