Thread: Pool design feedback ???
    Hi,
    My wife and I like non rectangular pools but we want an auto cover and there's negatives of curves with auto covers (thought it can be done). So we thought about a rectangular pool with underground shelves (with different textures than bottom of pool to stand out)inside the pool which make it look like curves. So one end of pool would have baja shelf and middle would have sitting shelves and other end just sitting shelves or stairs. So cover closed, looks rectangula. Cover open looks curved. Anyone do this?
    1) You can see the 2D picture here: http://sketchup.google.com/3dwarehouse/ ... revstart=0
    2) Or you can walk thru the 3D model by downloading it and installing Google's (now Trimble) free Sketchup SW (just takes 5 minutes). Dimensions are correct within 5/10 % error. Download and installing the free application here: http://www.sketchup.com/intl/en/download/gsu.html
    If you install the app then Click on View-->toolbars-->large tool set. Use the Orbit, zoom in, zoom out, hand, eye, and feet icons to move around.
    Any feedback is greatly appreciated.
    Thanks !!!
    9,000 gal. in-ground concrete pool
    Sta-Rite Max-E-Pro pump and motor (1 HP)
    Pentair CC100 cartridge filter (100 sq ft)
    Zodiac MX8 suction pool cleaner
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Re: Pool design feedback ???
    Embrace the rectangle! Ok, I'm biased as we are building a rectangle and getting an auto cover. Though I'd probably want a rectangle anyway.
    I will say though, in all honesty, when people attempt to make something look like something else, (in the pool world or not) it doesn't always work well. That said, we are going with a fake stone wall and decking made of concrete, but I have seen it in person to ease my apprehension.
    You might end up sacrificing utility for appearance with the curves within a rectangle. Your one side bench gets quite skinny towards the ends from the 2-D picture.
    I do like your outside the box thinking though. [WINKING FACE]
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Feb 2013
    Phuket, Thailand
    8
    I don't see any reason why this would not work. It may be a bit more in construction costs but not that much. You may have to increase the clearance at your spa/waterfall steps a bit for the cover.
    And I would put some more windows in the house. It is going to be really dark in there.
    Pool not built yet: 15K gal, IG Concrete/Tile, Perimeter Edge, Balance Tank, Diamond Kleen Filter, SWG, spec'd so far.
    Nov 2011
    Moberly,MO
    1,010
    joe anything is possible if you have a knowledgable builder. You could build a shaped pool pour a first deck then attach your cover track receiver then pour a second deck. This is often called a pool-in-a-pool. We build them pretty regular it makes a very professional ad finished look since cover tracks are hidden.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
