Results 1 to 10 of 10
Thread: Pool Problem
    Pool Problem
    Any suggestions how to solve this problem?
    [attachment=0:lvpomxk7]pool.jpg[/attachment:lvpomxk7]
    Gary R
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    22,553
    Re: Pool Problem
    Move here! We don't eve know what that stuff is!
    Re: Pool Problem
    White algae, appears to be all over your trees too.
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Pool Problem
    Wetsuit
    Mar 2012
    Amarillo, Texas
    341
    Re: Pool Problem
    A new skating rink?
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    38,463
    Re: Pool Problem
    Around here things would grind to a halt. We had the "Blizzard of 2013" ... and some schools were closed due to the dusting of snow.
    4knights's Avatar
    NE Kansas
    419
    Re: Pool Problem
    Wait! I don't see the problem other than you are missing about 8 inches of snow. My pool looks similar except we're not lacking that extra 8 inches. Makes sure those bugs are dead when spring hits and helps us appreciate the heat that much more!
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Pool Problem
    I want to see another picture after the thaw.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Re: Pool Problem
    Here's our normal mid-summer look!
    beating-the-heat-t48138.html
    Thanks for all the great replies, it made for an entertaining snowy day!
    Regards,
    Gary R
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Pool Problem
    .......I was out this past weekend in my backyard......with my snow shoes on.......the snow is almost as high as the pool wall and where I pile the snow is HIGHER than the pool wall
