Thread: FloVis, can it be installed in a 90 degree valve
    Jun 2011
    Long Beach, CA
    2,781
    I know the FloVis can be retrofitted in a Jandy 7305 check valve, but will it work accurately in a Jandy 7512 90 degree check valve? I've been having problems with my SWG flow on low speed, sometimes it works other times not enough flow, and I'm wondering how close my system is to the 30 GPM requirement that the the SWG has. My problems with the flow started when the new trisensors with the board were installed. I don't want to say I have a problem with the trisensor yet, as I might not have enough flow and the trisensor is doing its job as it should.
    If the FloVis will not work in the 90 degree check valve, I believe can remove the guts of the check valve and install the FloVis a foot down the line from that check valve. The check valve is on the heater out line and then turns 90 degrees up and then a straight section to the SWG. Does anyone see a problem installing the FloVis this way?
    22,544
    Re: FloVis, can it be installed in a 90 degree valve
    Hopefully phackett of Flovis will respond, but I suspect that it would be pretty accurate even in a right angle check looking at the way it's designed. Especially at low flows.
    Jun 2011
    Long Beach, CA
    2,781
    I have been updated, and it will not work accurately in a 90 degree valve. The best place for my situation will be to install it right before my SWG.
