Thread: Liquid chlorine burnoff using Liquidator
    Hi, I have a question regarding the liquid chlorine burnoff. I don't know if burnoff is the correct term. I am interested in buying a Liquidator. However, I live in Florida and the sun hits the pool a good ten hours of the day. I was concerned that the liquid chlorine would lose its potency before it got used up. Thanks in advance.
    Rainman
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Are you talking about the chlorine in the Liquidator or the chlorine in the pool? If you are concerned about what's in the Liquidator, you'd probably want to shade it some way or another. It won't get any hotter than the pool water as long as the pump is running.
