Thread: Help identify a valve
    Can someone help me identify what the circled valve in the attached diagram does? I bought this home a year ago and can't determine the purpose of theis valve. Thanks in advance.
    inground pool 20,000 gal vinyl- sand filter not sure of size or flow rate
    22,553
    Re: Help identify a valve
    It has to be a suction port somewhere in the pool. Look for a wall suction somewhere.
    Feb 2008
    Denton, TX
    5,061
    That's very strange. If there wasn't already a "pool vacuum" port identified already, a wall suction vacuum connection would be what I would guess. But one of the valves clearly says "pool vacuum" already.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Any chance it goes to the main drain?
