Results 1 to 13 of 13
Thread: What to do to prepare for SWG install?
    Jul 2011
    Austin, Texas
    78
    I just bought an AutoPilot Digital with the SC60 cell from Josh at saltpoolguys.com. If you are in the market for SWG then call them or PM JoshU first and you won't need to waste your time looking any further.
    My new system will be here on Tuesday. I will install on Wednesday. What do I need to buy and do before the install?
    I know I will need salt. How much salt will I need? I assume that I just buy the water softener salt from Home Depot/Lowes, right? Anything special to know about salt selection?
    My current pool readings are:
    FC: 11 (I'm just finishing up shocking the swamp )
    PH: 7.2
    TA: 90
    Borates: 60
    CYA: 25 (I'm currently adding this with the sock method but where do I stop?)
    The water is (finally) crystal clear.
    What adjustments do I need to make before the SWG?
    30K IG, Plaster with spillover spa, 9 ft deep end with spring base diving board
    48sqft DE Filter, 3HP VS motor, Hayward SPII, Raypak RP2100 Propane heater
    AutoPilot Pool Pilot Digital with SC-60 and pump relay (220v)
    Polaris 280. Pentiar Booster Pump, TF-100 Test Kit, Speed Stir
    Austin, Texas (It's hot)
    Re: What to do to prepare for SWG install?
    Look for salt that is 99.4% pure or better and doesn't have any rust inhibitor or other additives. The best choices include Diamond Crystal® Solar Salt Extra Coarse Crystals in blue bags, Morton® White Crystal® Water Softener Salt in blue bags, or Diamond Crystal® Sun Gems® Crystals Water Softener Salt in yellow bags.
    You will need enough salt to raise the level by between 2000 and 3000 ppm. I'd go ahead and get the full 3000 ppm worth, though you likely won't actually need all of that right now. You will use it eventually, though it might be till next spring. Wait for the SWG to have 24 hours to settle in and then look at how much salt it says to add (making sure you setup the pool size correctly). The starting salt level is likely to be well above zero. Letting the SWG figure it out allows you take that into account.
    Your target with CYA is 80, but don't raise it up that high all at once. Move along in steps of 30 or so ppm at a time and sneak up on your target level. If you go too high it is difficult to lower, while if you undershoot you can always add more.
    Jul 2011
    Austin, Texas
    78
    Jason,
    My local Costco has the Diamond Crystal Bright & Soft for $4.99. Is this a good salt to use? Is this a good price?
    Here is the product page: http://www.diamondcrystalsalt.com/Wa.../Products.aspx
    Jul 2011
    Austin, Texas
    78
    According to the Pool Calculator, I need 731 lbs of salt to get to 3000. Whoa! I'll probably have to make two trips for that!
    Ft Lauderdale, Florida
    1,455
    minor correction, but with 30K gallons, you need 750 lbs. It won't hurt the Pool Pilot if you add a little more, but 750 works out to 15 x 50 lb bags.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Jul 2011
    Austin, Texas
    78
    Sean, is this salt okay? Here is what the Diamond Crystal website said about the product:
    Highest-Purity: Up to 99.8% pure salt
    Advanced Performance formula—for softener efficiency
    Virtually 100% water soluble
    Patented double handles—for easy lifting
    It's the "Advanced Performance formula" that's got me worried.
    Please advise
    38,521
    As Jason eluded to, you are not likely starting at 0ppm of salt so do not add all 3000 ppm at once.
    Also, we usually recommend the Solar Salt as there are no additives. The Bright & Soft says it is an "advanced performance formula" ... to me that means there is some kind of additive that may not be good in the pool.
    Lowes / Home Depot have solar salt for less than that ... generally look for blue bags, but verify that there are no additives.
    Jul 2011
    Austin, Texas
    78
    Okay, thanks. I did see the blue bags at My Lowes. The price is the same at $1 per 10 lbs. (It's $3.99 but it's only a 40 lb bag) The salt purity is higher on the Bright & Soft but, as you said, I don't know what the "formula" is.
    38,521
    Still cheaper than the "pool salt" which is usually $7+ ... and all it is is the solar salt sent through a grinder to make it smaller.
    Jul 2011
    Austin, Texas
    78
    I received my new Digital Pool from Brown today.
    I need some advice on where to install the manifold. If you will look at the picture below you can see the return pipe for the install. I have two choices. I can put it either side of the pipe going from the pump to the filter. My first thought is to remove the chlorinator and put it there but then do I still leave the check-valve upstream of the SWG? ...or do I need to remove that? If I need to remove it, then I will put it back where the check-valve is now.
    38,521
    I suggest you review the manual that came with your SWG ... I am not sure what that one looks like and what its installation requirements are as far as minimum pipe lengths before/after.
    I will say that it should be the last thing before returning to the pool and definitely should NOT be put before the filter unless you desire a built-up of explosive gas in your filter
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    The cell should go down stream of the heater. Put it between the check valve, and the puck feeder. (You can) Remove the puck feeder, but keep the check valve.
    If you need more room because of the cross piping, cut the vertical pipes with enough room below the 90's for couplings, and raise the plumbing up.
    Factory Warranty Station for:
    Aug 2010
    Dallas, TX
    4,052
    After all this, I had to go back and get 6 more bags!
