Thread: Is this a problem???
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    Our pool was finished in November except for the plaster and water, I have been noticing this effervescence coming through the pool walls and through some of the joints on the face of the hot tub. I took a wire brush out and tried to scrub it off the rocks and mortar but its pretty stubborn. Does anyone know if this is a potential problem. PB says not to worry its normal. I don't want the nice stonework on the hot tub to be ruined by this.
    26,000 gallon gunite IGP with 50 sq ft Spa, Jandy VS FloPro 2hp Pump, Jandy DEV48 Filter, Jandy AquaPure SWG, Jandy AquaLink PDA-PS6 Controller, RayPak R406A Heater, Polaris 380 Cleaner, completed April 2013
    30,403
    Re: Is this a problem???
    Efflorescence is not a structural or dangerous problem but it is certainly unsightly and can be VERY difficult to remove. I would remove it from the finished areas with a bristle brush and a solution of water/muriatic acid. I would start with a 4:1 water/acid ratio but be prepared to strengthen it. You will know it's working when it "sizzles" or foams up.
    Use it only as needed because it will react on the grout, too.
    Getting efflorescence on unfinished gunite/concrete is very common and not a problem. Getting efflorescence on finished stone work is common enough, but suggestive of the possibility of real problems. Efflorescence happens when water seeps out through the mortar. However, water shouldn't be getting behind the mortar of finished stone work in the first place.
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    It's strange because there has been no water in the spa so I don't know where that could be coming from
