Thread: Problem with my Weber grill
    Baton Rouge, La.
    75
    I have the Weber Genesis Gold (5 years old) and starting a few weeks ago the temp stays between 450-500..even on low. Anyone know whats up with it?
    Harry
    Trilogy "Fiberglass" Pool,
    15x34 8900 gal.
    Pentair 1hp Super-Flo Pump
    Pentair CC100 Cartridge Filter, Pentair "Legend" Cleaner
    ktdave's Avatar
    Katy, TX
    888
    Sounds like you need a new thermometer. Try disassembling the therm. and cleaning it real good, put it back in, fire up your grill to test.
    Unfortunately, in my search, there appears to no longer be exact replacemant parts for your (and mine for that matter) grill. That said, you can always get a universal therm. to replace it with. I found one HERE. Hope this helps.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Baton Rouge, La.
    75
    Thanks...but the thermometer is brand new..got it at Ace hardware. Also put a stove type inside and it reads same temp. Called Weber and they said it is manifold problem so I'll take it apart next weekend I have free or send Weber 41$ for a new one. Harry
    Weber still makes the replacement "309815" Ace has them for 11.99
    15x34 8900 gal.
    ktdave's Avatar
    Katy, TX
    888
    Quote Originally Posted by HarryMichael
    Weber still makes the replacement "309815" Ave has them for 11.99
    good to know, thanks!
    Pool School
    TF Test Kits
