Results 1 to 10 of 10
Thread: Not algae, but some kind of bug??
    Feb 2013
    Houston, TX
    50
    I'm in the process of getting our "pond" back to a pool. I had noticed those dreaded backswimmers, but taking a real close look at the water, I found these guys. No idea what they are, but they're teeny tiny up to about this size here. Super gross looking and they twist and twirl around real quick like little weird worms. Almost looks like they could be some kind of evasive parasite you don't want to get into the water with! Any ideas what they are and if they'll die once I get the pool clean and clear and algae free again??
    Julie
    ~27,000 gallon 18'x36' IG concrete pool built approx. 1969
    FNSP36 Pentair DE filter w/ 1hp pump
    coping, tile, plaster redone March 2013
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Not algae, but some kind of bug??
    JulieS1007:
    I'm no entomologist, but my hunch is that those "worms" may be the larval form of some insect. Proper chlorination almost always eliminates the problem of bugs in the water.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Looks like good ole year round Texas mosquito larva. If you don't add chlorine they should come to the surface soon as pupa then emerge as your friendly coastal mosquito. Just get your FC up and they will be gone soon.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Feb 2013
    Houston, TX
    50
    No, they're definitely not mosquito larvae. I can spot those guys easy. These are more reddish orange in color and more worm looking than mosquito larvae. If they were larvae of some other bug, would they vary so much in size? I saw several different sized ones.
    Julie
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Ok. Maybe midge larvae, they have an orange look. Just get your FC up and they should be gone.
    30,414
    I think Julie is right.....them critters ain't skeeters!
    Like everyone else, I'll bet chlorine will do the trick.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Have you nuked that pool yet?
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Feb 2013
    Yukon, Oklahoma
    220
    Other than the color, they look like the web worms I get on my trees up here in Oklahoma about every other year. Do you have trees close by?
    I haven't had an issue with them up here because it has been so dry, but as soon as we get some moisture I am sure they will come out again......I too would like to know......have you bumped the chlorine level up and/or vacuumed them up?
    Bob E.
    Feb 2013
    Houston, TX
    50
    Never figured out what they were, but after several days of keeping the chlorine at shock level they were gone! I guess they ended up dying and sinking to the bottom because I think I only saw maybe one floating dead one. I've since netted and vacuumed the floor and haven't seen any since! Thank goodness!
    Julie
    Aug 2010
    Dallas, TX
    4,052
    Something to think about... since I added borates, I have far less issues with bugs and such in the pool.
