Thread: Mighty Vac vs. Q Vac vs 5 HP shop vac
    Oct 2012
    209
    Hey All,
    In your opinion which vac is better to set in-ground liners with? The Balboa 2.75 HP Mighty Vac, the Q Vac, or a standard 5 HP shop vac?....and why? Also is a smart box (auto vac and water shut off) a good investment? We have been using our 5HP shop vac and I am shopping for another, but don't know if the other options are really any better than another shop vac.
    Thanks!
    PJ
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    30,415
    Re: Mighty Vac vs. Q Vac vs 5 HP shop vac
    The forum is made up mostly of residential pool owners so you might not get a quick response to a commercial question. We'll see what happens.
    22,545
    Most consumer shop vacs are not designed for continuous duty and that would be the drawback of using one of those for setting liners especially when the set is protracted over several hours or even overnight. Also, realize that a so called 5 hp shop vac is really only about ½ hp or less. A 5 hp motor at 120 volts would draw about 50 amps.
    Feb 2011
    Petaluma, Ca
    665
    Really, Why is it called a 5 hp then?
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    22,545
    It's a marketing ploy. They call it peak hp which is roughly equivalent to the locked rotor amps. It's completely useless.
    Mar 2012
    Cincinnati
    33
    Q Vac all the way I have hung liners with all of the above
