Results 1 to 17 of 17
Thread: buy in a few weeks help
    Feb 2013
    Fort Wayne, Indiana
    16
    #1
    Ok i need some help on picking the pool and dealer so far this is what I'm looking at
    http://www.thepoolfactory.com/heritage- ... -oval.html
    or
    http://www.nationaldiscountpoolsupplies ... -pool.html
    or
    http://www.poolsupplyworld.com/abovegro ... ?pid=84948
    PSW has no liner and at 3-500 makes a big diffrence
    I have a intex salt generator now i would like to use cause i like the salt pools and that is why the national pool appeals to me... but after lots of reading here may just do bleach. don't want to waste money, but want it to be very nice... the nation pool with the alum sides and resin bottom track, resin top and bottom couplings... but would i get it and have holes in the alum sides or missing half the parts??? Any feed back on the pools, type of pools, and dealers I'm looking at would be great. Nationaldiscountpools i have heard nothing about makes me leary.. The other i have heard only good...
    #2 filter and pumps i was looking at this
    http://www.amazon.com/Hayward-S210T93S- ... filter+210
    would it be better to get a 2 speed and buy a different/ bigger filter or would this one be just fine... is there a better priced brand with a better combo should i get a 1.5 pump and a 26" filter..... help
    sharkline matrix 18x33x54
    SD80 filter
    hayward matrix 1hp 2 speed pump
    Tf-100 can't live without it
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: buy in a few weeks help
    Have you looked at this pool? http://www.namcopool.com/contempra
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, jrr426
    For your future ~15000 gallon pool, we would recommend a sand filter that is at least 2.8 sq. ft (which is ~22 in. diameter).
    A 2-speed pump would be a good choice.
    Something like this could work: http://www.poolsupplyworld.com/Penta...0060DO2260.htm
    Feb 2013
    Fort Wayne, Indiana
    16
    Quote Originally Posted by ComputerGuyInNOLA
    i actualy have and they do look great for sure... I need an oval pool i am replacing a 15x30x48 and it sets into my deck, i plan on cutting the deck out just a bit to get a new 18x33x54 to fit...
    linen thanks for the heads up on the pump filter. for some reason ihave a hard time finding dual speed pumps... i big can i go with the sand filter befor it is to big.
    thanks jrr
    SD80 filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by jrr426
    The only limit on sand filter size is the ability to properly backwash it. Generally, most manufacturers recommend 15 gpm/sq.ft of filter as a minimum flow rate for backwashing. For example that 1.5 hp dynamo pump (on high) can move about 48 gpm with pretty restrictive plumbing and move about 63 gpm with fairly unrestricted plumbing. Assuming restrictive plumbing (say 1.5 inch supply side size pipe that is not too long a run), that pump could backwash properly a filter that is 48/15= 3.2 sq ft. In reality if you have 2" supply size plumbing with a relatively short run from the pool to filter, when the valve is in backwash mode you probably are closer to the 63 gpm, which would mean you could backwash properly a 63/15= 4.2 sq. ft. sand filter. Reality will probably be somewhere in between, but bottom line is, unless you have really restrictive supply side plumbing, then you don't have to worry about being too big until your filter is larger than 3.2 sq.ft (24 inch)...and most likely with good plumbing up to 4.2 sq. ft (~ 28 inch).
    Feb 2013
    Fort Wayne, Indiana
    16
    So would I be better to get that pump and maybe pair it with a sd70 or is it more cost effective to just get the bundle with the sd60
    SD80 filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    In the end it will most likely be cheaper to buy a combo kit like the one mentioned above. However, if money is less of an issue, then I would buy the pump and filter separately. For example, I have the Hayward matrix 2-speed 1 hp pump right now, and it works great. However I am limping my 20" diameter sand filter along that I hope to replace when a good deal on Craigslist comes along. I am a looking for a minimum 24" filter to pair with my pump.
    Just a note: I just noticed looking at pentair's site I noticed that the turnover capacity and the high speed amps for the 1.5 hp 2-speed dynamo are actually higher than the 1.5 hp 1-speed dynamo, which the backwash numbers I gave above were based on.
    I also noticed that the Starite SRCF2022DO2160 appears to be same setup as the Pentair PNSD0060DO2260 (starite is owned by pentair now). Upon googling, I found it for $499 shipped: http://www.swimmingpoolsetc.com/pent...2022do2160.htm
    Feb 2013
    Fort Wayne, Indiana
    16
    Money is always an issue. I am really liking the dynamo 2 speed 1.5 hp... and i am really thinking about just getting the SD80 yes it is big but i think the pump can back flush it and i should not have to do it often.
    Also, think I'M going to get this pool. Looks like a pretty good deal.
    http://www.thepoolfactory.com/wizard/in ... /item/979/
    Unibead or overlaping liner, i kinda like the boarder look.
    Any input is greatly appreciated.
    I will try and get a picture of the pool currently this way i will have a before and after, will still be a few weeks till the buy but at least we can see the before and after.
    As always, truly appreciate the help, input, opinions, research you all give... always always appreciated
    SD80 filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Since I can't find a flow curve for the dynaflo 1.5 hp 2-speed...I looked at the flow curve for the 1.5 hp optiflo since the amperage is the same. If dynaflo curve is close to the optiflo, then it looks like that pump should be able supply the 15 gpm/sq. ft to backflush the SD80. Since you are thinking of buying separate you could also consider that optiflo (or the Hayward Matrix) 2-speed.
    Any interest in a deep end?
    Feb 2013
    Fort Wayne, Indiana
    16
    Deep is good, then i may consider a 52" so it would be a bit more shallow at one end. I will look at the other 2 pumps
    SD80 filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you do a deep end you will need an expandable overlap liner. Take a look at this thread: http://www.troublefreepool.com/one-f...nd-t41164.html
    Feb 2013
    Fort Wayne, Indiana
    16
    wow look at that matrix go
    http://www.hayward-pool.com/prd/Above-G ... 034__A.htm
    model im looking at SP15932S
    link to the data
    91GPM is that rite
    I will have the pump/filter next to the pool so the piping will be very short i would guess <10 to the filter and <10 feet the pool
    can i have a deep end with an oval pool are there not straps across the bottom...
    SD80 filter
    Feb 2013
    Fort Wayne, Indiana
    16
    The pool that came with my house that i am looking at taking to salvage. 15x30x48 with deck... maybe i should put it on craigs list
    http://imageshack.us/a/img560/6775/pumpheatareag.jpg
    http://imageshack.us/a/img198/4236/poolformend.jpg
    http://imageshack.us/a/img194/6403/poolfromdeck.jpg
    SD80 filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would recommend going with the sp15922s (1hp 2-speed) it has plenty of flow rate for your pool/filter. Also, the 1.5 hp you showed will probably only give you slightly more flow rate then the 1 hp. You most likely will not get close to 91 gpm under normal conditions...more likely in the 50s.
    Some newer ovals do not have straps afaik, but the older strap models can also be modified to not have straps across the deep area (but requires some more modification/work).
    Why are you replacing your old pool? Would converting it to a deep end remove the need to replace? Your current setup looks great to me! Cheapskate here
    Feb 2013
    Fort Wayne, Indiana
    16
    Quote Originally Posted by linen
    I wish, the liner is no good big holes. The pool walls are rusted thru at the bottome i would say 25% around and 1-3" up. the pump is froze up the the pump is cracked.. o let me count the ways.
    I talked to my wife and I think we are gona stick with all the same depth, so we can play vollley ball. it will be easer when my daughter has friends over, wont have to watch as close. (10 years old). will the 1hp pump back flush the sd80 also looking at the 24" form hayward.
    SD80 filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Ahh, that makes sense...not sure you will get any buyers on CL for it then. Maybe the deck.
    As for the deep end, remember they are only little for a short time. Deep ends keep the pool interesting for longer. Also, children should never be left unsupervised regardless of depth.
    Yes, either one.
    Feb 2013
    Fort Wayne, Indiana
    16
    Updated my signature I have ordered the pool and liner. I decided on the sharkline matrix 18x33x54 and a unibead liner. Pool supply world I love you! I will be buying my SD80 from them in another week or 2. Also decided on the hayward matrix 1hp 2 speed. If anyone has a good supplier for the gorilla pad at a good price would love to hear about it.
    SD80 filter
