Results 1 to 13 of 13
Thread: green pool
    May 2008
    South Central PA
    20
    green pool
    I looked under the winter cover yesterday and saw green. Is it okay to get in a pool with algae?
    I have to get in to brush the walls and floor.
    Did test the water:
    FC 0
    PH 7.4
    TA 90
    CYA 30
    13,500 gallons
    Mike
    13,500 gallon AGP, 1-1/2hp pump 150# sand filter
    No it isn't safe to get in a pool with algae. If there is algae then there can be pretty much anything else in the water as well. It isn't likely to kill you, but it could have unpleasant effects. Try shocking the pool with only the brushing you can do from outside the pool and see if you can get it to hold at least some chlorine level before you get in it.
    May 2008
    South Central PA
    20
    Would it help to keep the winter cover on to kill the algae or would that hinder it? (I removed all the water
    and other junk from the top of the cover)
    Mike
    Keeping the cover on will slow the growth of the algae dramatically but it won't kill it. I would leave the cover on till you are ready to deal with it and then do everything at once (cover off, fight algae).
    May 2008
    South Central PA
    20
    is it possible I still have algae and not know it? Pool looks crystal clear, chlorinator on max. Normally I can have it
    set on 2 (1-9) I'm only getting .5 of FC I'm adding ultra bleach every couple of hours. I brushed the whole pool.
    The pucks are dissolving. pump running 24/7
    It does take a few hours for the FC to drop that low after dumping the bleach in
    could it be my cya is inaccurate? The pool store also tested it and got the same results as I did
    reading:
    PH 7.4
    FC .5
    TA 120
    CYA 50
    Any ideas
    Mike
    May 2008
    South Central PA
    20
    forgot TA reading is 120
    Mike
    You might have algae or ammonia. Does the FC level fall at night as well as during the day? If so you need to shock the pool and maintain shock level until the FC holds steady overnight.
    May 2008
    South Central PA
    20
    I had some ammonia test strips for my fish tank I checked it appears to be zero
    Mike
    May 2008
    South Central PA
    20
    I added more bleach about a .5 hours ago and got about 5 FC reading so I should be near that level before the sunrises?so if it holds should I look at my CYA?
    Mike
    Right.
    May 2008
    South Central PA
    20
    Jason I want to thank you for all your help. I want to ditto that about the other post for the MVP
    Mike
    30,426
    Hi, Mike,
    Chlorine in your pool is reduced by two things...the sun and organics (algae) in your pool.
    By adding the FC in the evening, testing the result, and then testing again the next AM before the sun hits your pool, any chlorine loss (greater then 1.0ppm) is attributable to algae.
    So if your 5.0ppm you started with tonight is down to 3.5 or lower tomorrow am, that's a good indicator there is still algae in your pool.
    You need to shock if that's the case.
    May 2008
    South Central PA
    20
    I 'll be up first thing tomorrow to check, thanks
    Mike
