Thread: layer of fine dirt on the bottom of the pool
    Jan 2013
    Sydney, Australia
    31
    Hi,
    I have a layer of fine dirt on the bottom of the pool, the robot stirs it up weekly and its murky for a few days till it settles.
    What is the best way to get rid of this, I was thinking of doing a vacuum to waste, if that makes sense, should I FLOC it at the same time to maximise the amount of particulates we remove?
    Thanks.
    Richard
    In-ground pebblecrete, 16000 gallon, sand filter, salt chlorinator
    30,424
    Re: layer of fine dirt on the bottom of the pool
    Have you tried manually vacuuming it?
    steinholder's Avatar
    Mar 2012
    Wichita, KS
    81
    Vacuum to waste ought to do it...
    22'x52" AG Ultra Frame Intex - 12,500 gal (47K liter)
    Manual Liquid Chlorine - 1HP 100# Hayward sand filter
    Lots of sun, trees, pollen & wind - 50ppm Borates
    4nd season grateful TFP fan
    30,424
    Forget the floc. Vacuum slowly to get as much as you can. If you have CHEAP water, vacuum to waste is fine but no more effective than vacuuming from the filter position. (you may have to clean your filter)
    How did it get there in the first place?
    Sep 2009
    Greentown, IN
    914
    How have your numbers been running.
    The couple of times I have had problems with fine debris on the bottom of the pool it was either spring and pollen, a heavy bather load that used lots of sunscreen, or the start of a small algae bloom and it was probably dead algae on the bottom.
    Make sure your numbers are in check and if your FC may have been low at all give it a good boost, if not a shock.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
