Thread: Bids are in, here is the one we are thinking
    Feb 2013
    Metro St. Louis
    93
    We got 3 bids, and have been narrowing it down. Please find below the equipment/cost, plus some items I bounced off the PB to get his thoughts.
    This is for the one we are liking so far. We are located in Missouri.
    Pool Specs
    * In ground vinyl liner 20x34 lagoon shaped 6' deep
    * Hydra Pinnacle panels
    * Liner by Premier (PB says liner seamless this year, big improvement visually)
    * Wedding cake interior steps
    * Rock backfill
    * Drain Tile around perimeter of pool, Pool Krete under liner (is this drain tile enough??)
    * EasyTouch 4 or 8 with actuators for water feature and deck jet ($1800 upgrade)
    * IC40
    * Pentair Cartridge 420
    * Pentair IntelliFlo (or IntelliPro) VS pump ($600 upgrade from single speed)
    * 48" stone planter water feature with 36" Pentair MagicFalls sheer descent ($4000 upgrade)
    * Single Pentair deck jet ($200 upgrade)
    * 2 Pentair IntelliBrite 5g pool lights ($1400 upgrade)
    * Pacific mesh safety cover ($2900 upgrade, seems high?)
    * 2 Skimmers, individually plumbed for equalization
    * 2 Main Drains, plumbed separately
    * Stone coping around perimeter of pool ($4500 upgrade)
    * 1274 sq/ft of concrete decking, fiber reinforced ($1800 upgrade)
    * Spray deck type coating ($5000 upgrade)
    * One outlet on pool backside
    * Four umbrella sleeves
    * 120' of 54" aluminum fencing, with 2 gates
    * 24' of 6' vinyl fencing, to hide equipment
    * Gas line for future heater
    * Gas line to 3 gas tiki torches
    * Demo existing deck
    * Rebury downspouts
    Total Cost: $66,000
    Questions
    * PB stated stamped concrete can be really slick when wet, and hot - Recommended their "spray deck". Similar to SunDek/KoolDek. Is a $4 sq/ft upgrade. Worth it?
    * PB stated variable speed pump would be IntelliPro VS-3050, but this shows discontinued on some sites. I was wanting IntelliFlo VS. Not sure what the difference is, or which would be best??
    * Stone Planter (48" by 24" by 18" tall) will sit on gravel before concrete deck pour, any recommendations for extra support? This one is very similar, but much larger: http://www.troublefreepool.com/under...t52104-20.html
    Any input would be much appreciated!!
    Paul
    Sterling Steel IGP lagoon 21' x 35' w/6' deep end, Pentair 5g LED lights (x2), Pentair Landscape LED light, Pentiar IntelliFlo VS pump, Pentair 420 Cartridge filter, Pentair IC20, 4 gas Tiki Torches, LoopLoc Ultra Loc II, Deck Jets(x3), Raised Planter Bed with 3 Pentair bronze sheer decents, AquaBot Breeze 4WD, Pentair Legend II
    Nov 2011
    Moberly,MO
    1,010
    Re: Bids are in, here is the one we are thinking
    Also I would lean toward a sand filter instead of the cartridge since you aren't putting an auto cover on. Also personally I would get a solid cover not a mesh. Everything else looks pretty good to me.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Feb 2013
    Metro St. Louis
    93
    Thanks for the advice swimcmp.
    Also, we would like to get another bid...if anyone has a positive experience with a St. Louis PB...feel free to share
    Paul
