Thread: A unique water source indeed
    Apr 2008
    Indonesia
    311
    Hi Gang,
    Carry over from previous post :
    now-how-fresh-is-fresh-water-t53049.html
    So the story goes that 17-22 nd Jan 2013 was flooding in my city.
    I did not re-do the pool till few days back, as I was waiting for rainy season to be over. No point getting my pool flooded twice within 30 days
    I spoke to the water supplier company and demanded him to source the best water with lowest TDS and organic load and whatnot.
    As I was not happy with the previos water he supplied me :
    allright-tpf-alumni-changing-pool-water-in-real-time-t51352.html
    He said there is a source which will suit me but it will cost me much much more. 60 ish PPM TDS he said, same mother nature water supply as bottled mineral water brand called AQUA ( now owned by Danone - French ) http://www.aqua.com/home
    So I said, bring in on and I am keen to try.
    The peak of the flood 18th Jan 2013, see the stainless steel pool ladder nearly 100% submerged.
    [attachment=2:12elsmfy]18th jan 2013.JPG[/attachment:12elsmfy]
    By 22nd Jan 2013
    [attachment=1:12elsmfy]22 jan 2013.JPG[/attachment:12elsmfy]
    All I could do was to dump chlorine to 20 PPM on the flooded pool and slowly draining the water but not to empty level.
    I fear the pool will be lifted up by ground water hydraulic force in such rainy season.
    A week ago, clean the pool perimeter first. Scrub with detergent all floors and wall.
    Use jet spray and 20PPM chlorine to disinfect pool perimeter.
    Bring water level to the shallow portion less 30 cm.
    Scrub shallow area pool tiles with detergent and then 20 PPM chlorine using jet spray
    Few days back in preparation of new water coming, drain the pool to zero level
    Scrub pool tiles with detergent and then 20 PPM chlorine using jet spray
    [attachment=0:12elsmfy]a1.JPG[/attachment:12elsmfy]
    Will continue...............
    35,000 GL pool. In Ground. Concrete with all white ceramic tiles. Outdoor but shaded.
    Approx 36 ft by 15 feet. 2HP Hayward Super Pump, Hayward Sand Filter with Zelbrite ( Zeolite ), Hayward Cartridge Filter, Aquamatic Silver+Copper Ionizer ( suspended use since Oct 2008 ), Prozone Ozonator, 2 gram/hr, Analog Flowmeter on pipe
    Back Up Pump & Filter on trolley, Pentair 1.5HP + Pentair Cartridge Filter, Slime Bag 1 micron Jumbo Size, downstream of Cartridge
    Apr 2008
    Indonesia
    311
    Re: A unique water source indeed
    [attachment=2:jv9nhjku]a2.JPG[/attachment:jv9nhjku]
    [attachment=1:jv9nhjku]a3.JPG[/attachment:jv9nhjku]
    D-Day comes the water
    Total 6 trucks of 8KL ( 8,000 liters )
    [attachment=0:jv9nhjku]a4.JPG[/attachment:jv9nhjku]
    Will continue................
    Apr 2008
    Indonesia
    311
    Must do it 11PM upwards to get fast re-supply of water from the moutains
    [attachment=2:1tdvgqqv]a5.JPG[/attachment:1tdvgqqv]
    Measured TDS, 63.8 PPM. The seller did not lie to me
    25.9 Celcius water, that is not a lie, this is from the mountains or else it will be 28C at best
    [attachment=1:1tdvgqqv]a6.JPG[/attachment:1tdvgqqv]
    6 x 8KL trucks get me this much
    [attachment=0:1tdvgqqv]a7 - 6 x 8KL trucks.JPG[/attachment:1tdvgqqv]
    Dumped chlorine to make 10 PPM FC..................
    Apr 2008
    Indonesia
    311
    [attachment=2:2ge6rwqm]a8a - 12 x 8KL trucks.JPG[/attachment:2ge6rwqm]
    [attachment=1:2ge6rwqm]a8b - 12 x 8KL trucks.JPG[/attachment:2ge6rwqm]
    Very strange, I keep adding chlorine to make 10 PPM FC but I can not get water to burnt off its algae and whatever baddies. This is totally different from allright-tpf-alumni-changing-pool-water-in-real-time-t51352.html
    I think I get my money worth from this water
    NEXT day, still water is not "algae factory"
    [attachment=0:2ge6rwqm]a9 - waiting for midnigth and 5 more 8KL trucks.JPG[/attachment:2ge6rwqm]
    Apr 2008
    Indonesia
    311
    [attachment=2:ewp4ns6e]b10 - 17 x 8KL trucks.JPG[/attachment:ewp4ns6e]
    Keep dosing chlorine to make it 10 PPM with new water.
    STILL can not get any "algae factory" ...............**** this water is really clean !!!!
    NEXT DAY, daylight
    [attachment=1:ewp4ns6e]b11 - zoom test.JPG[/attachment:ewp4ns6e]
    [attachment=0:ewp4ns6e]b12 - zoomed.JPG[/attachment:ewp4ns6e]
    The water is not yet sparkling blue like I used to get.
    Apr 2008
    Indonesia
    311
    Today afternoon............ or 7 hours ago.
    [attachment=0:1m5k7x6h]b13 - Daytime.JPG[/attachment:1m5k7x6h]
    My 2nd pump on trolley was sent fo repair. It was 3/4 submerged and the bearing was making noises.
    12 PPM FC maintained.
    Let see in 48 hours will the water be sparkling blue ?
    I will submit for Lab Test again soon to share.
    Later Gang,
    SPP
