Thread: Jandy Lite 2 LG250N-C - Work with Salt Water?
    Hi, found a great deal on a used Jandy Lite 2 Natural gas heater, LG250N-C. Wondering if this will work to heat my salt water pool. I've searched and see that there might be a suggested model for salt water pools yet I cannot find a lot of info.
    Question for the group, can this unit be used with a salt water pool and if so, what if any issues could I expect?
    Thanks in advance for any suggestions.
    Re: Jandy Lite 2 LG250N-C - Work with Salt Water?
    Welcome to TFP!
    When heaters talk about salt water pools they normally mean ocean water pools, which have salt up around 35,000 ppm, and they are not talking about SWG salt pools, which have salt around 3,000 ppm. Just about any heater should work just fine with a SWG pool, though you do need to get a special kind of heater to work with ocean water levels of salt.
    Thanks so much for the quick response. Exactly what I needed to know, much appreciated.
    Sep 2012
    Lake Nona, Florida
    386
    In going through the paperwork on my new pool equipment I saw a bold print warning on a few items noting they were for use in "fresh water application only". Then in the small print underneath there was a note that a pool with a salt water chlorine generator is considered "fresh water".
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
