- Feb 17, 2013
- 3
We started our new pool on Friday, 2/15/2013. Pool Concepts by Pete Ordaz is our builder. Here are the specifications:
Pool Specifications
• 25’W X 32’L Custom Gunite freeform Pool per Plan
• 488 SF with 38 SF Spa
• Depth 3’6" X 5’6"
• 15350 Gallons
• #4 Steel Bar (½") Throughout @ 9" on Center
• #4 Steel Bar Bond Beam at least 3" from Soil
• 7-Sack Dry Gunite Mix
• Floors to be a Minimum 9" Thick
• Walls to be a Minimum 9" Thick
• Gemstone Pebble Series Pool Finish
• 6" x 6" Band of Frost Proof Tile to blend with Oklahoma Flagstone around Perimeter at Waterline
• Accent Tile on Steps and Benches
• Overflow Line included for Venting Excess Water
• One (12’) safety bench
• Oklahoma Flagstone Coping
• Two (2) Pots with Waterfall along back pool edge
• Two (2) 12’’ Tall Oklahoma Flagstone Columns for water pot features
• 8’x10’ Sundek in pool with bubbler and turtle mosaic
Pool Equipment
• Schedule 40 PVC Plumbing, 2" Diameter (Rigid Only) Plumbed around the pool
• Five (5) Adjustable Returns
• Two (2) Surface Skimmers
• One (1) Pentair 60 sq. ft. FNS plus DE Filter
• One (1) 3 HP Pentair Intelli-flo VS Pump
• One (1) Rainbow Inline 320 Chlorinator with Borate Mineral Liquid Harmonizer
• Two (2) 5G Intelli-Brite LED pool Lights
• One (1) Pentair EZ Touch 4 function wireless remote
• One (1) Kreepy Krauly Platinum Pool Vac with Booster Pump
• Two (2) VGB Compliant Main Drains
• One (1) Freeze Guard
Spa Specifications
• 7’ Round Gunite Spa with Arm Rest and 4’3" Standing Wall
• 8’ multi-tiered spillway
• 8 adjustable return lines
• 2 HP air blower with 4 button spa side remote
• 400,000 btu mastertemp heater
• 18” Raised above Pool Level Faced and capped with Oklahoma Flagstone
• (1) Intelli-Brite LED spa light with steel niche
• Gas Connection
Deck Specifications
• 600 SF of Sunstamp by Sundek with tooled expansion joints
• 20 SF of Oklahoma Flagstone Decking
• New Deck to be Reinforced with Steel Mesh and Deck Dowels in Beam 27" on Center
• Turn down beams to support deck
• All steps to be faced and capped with Oklahoma stone
• 3’ round wood burning fire pit faced and capped with Oklahoma stone
• Dropped Deck, Exposed exterior pool wall faced with Oklahoma stone
• (4) anchors/sleeves for Umbrellas, BB, or Volleyball.
Pool Specifications
• Depth 3’6" X 5’6"
• 15350 Gallons
Pool Equipment
Spa Specifications
• Gas Connection
Deck Specifications
