Results 1 to 7 of 7
Thread: Any reason I can't have auto-fill in TX?
    I was told a while back that we could not build a new pool with auto-fill due to some TX code (a water source?). Is there anything you know of that would prevent me from getting auto-fill in TX ? Am I missing something?
    38,547
    Re: Any reason I can't have auto-fill in TX?
    I thought the drought rules down there were geared against a total refill of a pool and did not prohibit maintaining water level. I can not imagine why an autofill would not be allowed.
    If you want to know for sure, talk to your county or city permit office.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Feb 2008
    Denton, TX
    5,061
    I have not heard of any auto-fill restrictions for the State of Texas. However, if your county is under drought stages, this might dictate that non-essential water usage be curtailed.
    Here is a reference from a utility:
    When topping off, use a hose timer to avoid overfilling. Add a few inches as needed on your scheduled watering day to maintain constant water levels. Auto-fill devices can malfunction and add water unnecessarily. Using a hose makes it easier to tell if a leak develops or the pool level changes dramatically. Austin Water Utility is owned and operated by the City of Austin, Texas.
    http://austintexas.gov/department/conse ... ming-pools
    I think that if it were against the building code, then they would say so.
    Here are two references from builders about installing an auto fill:
    So, if you don't have auto fill you might consider having one installed on your pool.
    http://www.fielderpools.com/index.php?o ... &Itemid=18
    I think that if it were against the building code, that they would not offer it
    Here is a reference that indicates that water from an "irrigation system" cannot be used:
    Use of Irrigation Systems for Pools and Fountains Fill
    1. What governs the installation of auto-fill equipment for pools and fountains?
    http://www.dallascityhall.com/pdf/Build ... tation.pdf
    I think that this is the most likely rule that the person was quoting, and possibly misinterpreting. If they say that an auto-fill is not permitted, then ask them to provide a reference.
    To be sure, you could contact your local utility and/or your local Building Inspections Department.
    Support the site
    Thanks so much for the info and links! I really appreciate it!
    Sep 2012
    Cypress, TX
    63
    For what it's worth, we are in Texas, just built and have an autofill. It was offered in all of the quotes we received.
    18,000 Gallon IG, Pebble Sheen, Quartzite coping
    Pentair 420 Cartridge Filter, 2HP Silencer, 400,000 BTU Heater, Platinum Legend Cleaner
    2x IntelliFlo VS pumps - Screenlogic Interface - Stenner 45MPHP10 15 Gal Bleach Injection
    TF100 + PoolCalculator + This Site!
    I always say... it's easier to ask for forgiveness than permission...
    How would anybody know?
    Texas rebel (I guess..)
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
