Thread: Draining Pool due to high CYA ; Gray moddling on UltraPoz
    Just joined TFP today and am very impressed with the knowledge here. I seem to be a tri-chlor tab victim causing high CYA. I have a CYA of 150 (knowing hard to gauge > 100). I haven't added chlorine in any form for about 6 weeks - water very clear as water temp is 45 degrees . I'm having the pool drained and will be switching to liquid chlorine as much as possible in the coming summer. The question is whether I should have the ultra poz surface acid washed to get it back to the way it looked when new? Is this adviseable?
    17,800 gallons; Cartridge; Pentair whisperflow 2HP pump; UltraPoz surface; Phoenix, AZ
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Draining Pool due to high CYA ; Gray moddling on UltraPo
    Welcome to tfp, pcman
    Quote Originally Posted by pcman
    I would think you could do an acid wash, though I am not familiar with your exact surface. Keep in mind that acid washes can take off scaling, but they also take some plaster too, shortening the overall life of the pool. Hopefully someone will be along soon that can answer you question Posting pictures of the scaling might not be a bad idea.
    30,426
    No need to drain your entire pool. Just calculate drain to get cYA down around 40 or so. I would suggest a 3/4 drain and go from there.
    What does it look like now? If it is bugging you a lot then go ahead and acid wash it with the caveat that linen mentioned above. If it's not bothering you much, leave it alone. adjust your pH TA and CH accordingly and the scale may slowly dissolve.
