Thread: In ground spa question
    Our recently purchased house has an in ground pool and spa. The spa operates when the suction and return are diverted to it, obviously, but I wonder if its okay to partially open the return in order to decrease the power of the jets while using the spa? Is it hard on the pump?
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: In ground spa question
    No it isn't hard on the pump but it will drain the spa unless you have the suction partially diverted as well. Plus if you have heated water, you will lose that too.
    Mark
    38,271
    You could try larger eyeball returns in the spa to reduce the force.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    mas985's Avatar
    Pleasanton, CA
    11,737
    The size of the eyeball is not going to make much of a difference but the size of the venturi jet nozzle will make a big difference.
    Mark
