Results 1 to 7 of 7
Thread: Pavers right to pool edge instead of coping
    techgirl's Avatar
    Vernon, BC Canada - Pool is in Maricopa AZ (currently a holiday place)
    75
    We are doing pavers around our pool and we don't love the look of the coping pavers and we're wondering if we can just run the paver pattern right to the edge of the pool?
    Thank you
    Inground 12500 gallon 96 foot perimeter, 24 by 24 pool (6 by 24 of which is a "wet deck" or tanning ledge), intellibrite in spa and pool, 2 pentair LED bubblers in tanning ledge, built in table in pool, spillover spa, pebble radiance, Pentair Mastertemp 400K BTU heater, Blue Square Q360 infloor cleaner, VS2050 pump, auto leveler, Pentair easytouch 4 with wireless controller, Pentair 420 filter, custom natural gas firepit with cobalt glass.
    Re: Pavers right to pool edge instead of coping
    Not at all easily. You could use a solider course of standard pavers in a coping pattern, but it is extremely difficult to just continue the main field pattern right up to the water.
    Coping is normally isolated by an expansion joint from the main field of pavers, and the portion of the coping right near the water is not fully supported the way the rest of the coping block is. Continuing the filed pattern right to the edge would result in occasional small pieces of paver right near the edge, which would not be sufficiently supported.
    Clarksville, TN
    126
    I am in the middle of a diy pool build and using pavers. I chose a concrete bullnose step tread at the water edge. I will butt my pavers up to this. I have seen a soldier course used with pavers, but it is a rough look and doesnt seem very secure. Most paver brands have other size options that will match there pavers. i.e wall caps, step treads, column caps, etc. These will give you a much stronger edge due to the larger surface area. Again, Ive installed lots of pavers and what you want can be done, but I wouldn't recommend it. I attached a pic of my coping and the pavers I'll be using around pool.
    34,000 gal., 20x40 Roman, IG Steel/Vinyl, 500# Hayward Sand Filter, 2HP Ecostar-VS, Savi Note LEDs, Autopilot Digital 220 SWG
    May 2011
    Tampa, FL
    130
    What color pavers are those?
    - Vanessa
    Almost done! 15x30 IG 3ft-8ft deep | SWG | Spa w/ 400K Natural Gas heater | Blue Granite Pebble sheen | JEP 1.5 VS pump | DE Filter | White/Tan/Charcoal Brick Pavers | Bronze Screen | Solar Panels
    May 2013
    Ocean County NJ
    183
    Very nice combo! Love the blue grey and sand colors. what color brand pavers?
    Freeform gunite, 14,000 gallon saltwater sport pool.
    10 ton moss rock w/ waterfall, 50 sq ft raised spa.
    Bluestone coping, pebblesheen. Jandy pro flo 1 hp pump, legacy 325k heater.
    Clarksville, TN
    126
    Thanks,The paver color is called "driftwood" in a Princeton pattern from Red River Concrete Products.
    What are your pool walls made of? If theyre poured cement, I dont think youll have any problem mortaring pavers down in a soldiers course fashion. If you have a safety cover, make sure teh anchors are very secure, and not relying on the pavers to hold them in, otherwise you may pop the mortar joint. This is what happened did our pool in before we rebuilt it, although we had a rotting wood beam under the pavers. We replaced with all masonry now, and the pavers make for a quite solid coping.
