Thread: SR Smith Salt Stand with 8' Frontier III
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Heya,
    Our last pool had an SR Smith 8' Frontier III with metal Cantilever Jump Stand.
    With the salt water, the stand was a battle to keep the rust at bay.
    So, the pool at our new house....we are getting the same setup, but with the Salt Stand.
    I presume this is a composite covered stand of sorts.
    The springy nature of the original pool diving board is desired for the new one.
    Wondering if anyone can verify the newer SR Smith Salt Stand is as good as the metal one in regards to performance?
    Thanks!
    35k gallon 20x45 inground concrete with vinyl liner - Stamped Concrete deck
    Pentair WhisperFlo 2HP - Pentair FNS Plus 60 DE
    Heat Siphon heat pump - Compupool cpx48
    Blue Diamond RC robot vacuum - TF100 testkit
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Re: SR Smith Salt Stand with 8' Frontier III
    In case it helps anyone else, I did have the SR Smith Salt Stand with 8' Frontier III installed with our recent pool build.
    I can confirm it is as springy/bouncy as the metal cantilever stand.
    So, same results but will be rust free as the entire thing is composite.
