Thread: Special heater for salt water pool?
    Sep 2007
    I am at the final phase of a new fiberglass salt water pool construction. I just noticed in the Sta-Rite pool heater owner's manual, it states that it should not be used for salt water pools. My PB has used the same heater for many other salt water pools and obviously has not had any problems. Any suggestions? My heater is the Max-E-Therm SR200NA.
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    They are talking about ocean water, which is about 12 times as salty. The heater should be fine with salt levels below 5,000 ppm.
