Results 1 to 7 of 7
Thread: DPD Chlorine Test FC and TC - Free Chlorine and Total Cl
    Jun 2012
    Escondido, CA.
    42
    Im trying to make heads or tails of this test.. I found here:
    extended-test-kit-directions-t25081.html
    Ive got a TF-100 kit and at step 6 of teh extendex directions it says to ...compare the shade of colr aginst the color chart.. What color chart?
    Escondido Ca [*]~23000 gallon plaster pool built in the 70's[*]Pentair VF Pump running 10hrs at 1800rpm getting and estimated 35-40 GPM thruput[*]Sta-Rite Cartridge filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Re: DPD Chlorine Test FC and TC - Free Chlorine and Total Cl
    Quote Originally Posted by BitViper
    The colors on the side of the test block. It's the one in the little blue box inside the big TF100 kit.
    It works best against a white background with good natural light.
    38,290
    The TF100 does not include the DPD test. In the blue box is the OTO test with the pH test. The instructions you want to look at are for the FAS-DPD test which uses the powder.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jun 2012
    Escondido, CA.
    42
    Ha!.. thats what I thought..
    Are the tests equivelent?
    Ive been using the "Extended Instructions" found on this site and thought they wouls translate to the TF-100.
    38,290
    IDK what you mean by equivalent.
    The FAS-DPD is the most accurate for FC and CC. The OTO is really only good at detecting the presence of chlorine.
    The directions you are looking at should describe the differences between the tests.
    No one test kit includes all of the tests described in The Extended Test Kit Directions. For example it describes three different chlorine tests, even though most kits only include one of them. Different kits come with different chlorine tests, so we described them all.
    Jun 2012
    Escondido, CA.
    42
    jblzzle.... THAT is exactly what I wa slooking for thanks... Guess I missed that detail... They arent equivelent... OTO is a "quick and dirty" test.. an the drop test the most accurate..
    Perfect
