Thread: Bleaching the liner???
    Fields's Avatar
    Jan 2013
    Columbia, SC
    43
    I was just talking to a friend about somethings I've learned while on TFP. One of the things he questioned was the use of bleach in a pool. He said that you could bleach your liner? Is there any truth to this? I have a deep blue liner and would hate to ruin it.
    27x52 Garden Leisure AGP, Hayward Dream Line 1.5 Sand Filter, TF-100 Test kit
    BBB and Loving It!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Bleaching the liner???
    No. Any form of chlorine can damage a liner if you are careless when adding it, but powdered chlorine is worse when it settles on the bottom. Once chlorine mixes with the water, all forms are the same.
    Any truth? Yes. Anything actually interesting or meaningful that you need to worry about? No.
    If you pour full strength bleach directly onto the liner, instead of into the water, you could potentially bleach the liner. But if you add it the way we recommend, by pouring slowly in front of a return jet while the pump is running it is nearly impossible to cause any damage.
    More importantly, this is true of all sources of chlorine, not just bleach. There are many sources of chlorine, including bleach, trichlor tablets, SWGs, etc. All of them have exactly the same effect as far as "bleaching" the pool goes. Sitting a damp trichlor tablet on the liner will actually cause more damage than bleach, since trichlor has chlorine and also is quite acidic, and acid is slightly more likely to cause damage than chlorine.
    [Different way of saying what JohnT already said.]
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Just to ad to this...
    The liner in our pool is significantly bleached from the previous owner's pool care which included trichlor and calhypo.
    Sent via Tapatalk...
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    A friend tried telling me the same thing once, ohh, and he was told so by the pool store that sold and installed his pool, ohh, and their recommendation was to regularily purchase a concoction of chemicals from their store.
    Last year he continually fought algae outbreaks.....I have yet to have an algae outbreak and my liner looks great. I buy no name bleach from the big box grocer or Walmart, or Clorox when only that is available, and test regularly with my test kit.
    As stated in pool school, poor your bleach in relatively slow and in front of the return port so it gets dispersed.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    The only time I ever damaged my liner was when a puck dropped to the bottom of pool.while on vacation. Sis in law accidentally did it. Sat there for two days. Bleach or liquid chlorine never been a problem. Dont worry!
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
