Results 1 to 11 of 11
Thread: Need help making a decision with a new pool build
    I currently have 2 bids that I'm working with. There is a 1200.00 difference between both of them but money is not a deciding factor. The difference both of them is:
    1. 2.5 and 3 or 1.5 and 2 plumbing. The company with the bigger piping claims that the larger pipe size will increase water hydraulics, better water flow and less noise. Is this true is there a benefit with this?
    2. Pebble Sheen or Stonescapes Mini Pebble. Here is the info i received. "The Quality of the trowelled finish and Warranty for Genuine Pebble Sheen is the major difference. Pebble Sheen can only be installer by a Certified Installer . There are only 2 in the Valley. Stonescapes can be installed by anyone. Warranty for Pebble Sheen is Lifetime and Stonescapes only has Limited Warranty from Installer." Is there really a difference between both, which is better?
    Thanks for your help in advance!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Need help making a decision with a new pool build
    Welcome to tfp, AZhusker
    2.5" and 3" inch may be overkill and the 1.5" and 2" are on the small side. Post some details and we can be more specific...pool volume, water features, hot tub or not, etc.
    30,404
    size of your pump as well.
    We are building a 80' perimeter play pool. The deeped of the pool will be 4'-4.5'-4'. There will be 2 water features which are 2'x2'x2' towers with 30" scuppers. No hot tub. The pump is a Sta-rite Intellipro variable speed HD pump.
    What is your opinion between pebble sheen and stonescapes?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    What they said is true; Pebblesheen can only be installed by certified folks, and anyone can buy stonescapes. That doesn't mean you won't get a great, long lasting installation of the latter, nor does it absolutely guarantee a good installation of the former. There's not much difference between the products themselves, you're just buying some amount of confidence that you'll get a better install.
    Having excessively large pipe won't cause any problems, but having pipe that is too small can.
    Thanks
    Sep 2012
    Lake Nona, Florida
    386
    The guy who did my stonescapes said that only certified installers could offer a stonescapes warranty. He was certified and I just registered my warranty. I agree that workmanship on the surface is make/break. I got my guy via solid references.
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
    Thanks for the information. I just make the right decision with such a large investment..
    Sep 2012
    Lake Nona, Florida
    386
    Quote Originally Posted by AZhusker
    yep, it's a big nut... nice to have experience here to draw upon. Good luck.
    Actually, there are 3. Just go to the PT website and select the locate a builder/installer. There are 3 listed in the valley, but one is a PB so I guess technically there are 2 installers. Just be careful of the word "Pebble". Lots of builders do their own and call it something similiar but it's not Pebble Tec, i.e. Pebble Radiance. I'm not saying it is no good, but just know what you are getting.
    38,254
    Best to check the website for installers. Many builders may offer Pebble Tec, but they will sub out the work to one of the installers ... and add a markup. Might be cheaper to talk to the installers ... That is what I did when we refinished our pool.
    Posted from my Droid with Tapatalk ... sorry if my response is short
