Thread: DE filter and SWG - any issue
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    I am relocating and the new house has a nice pool with DE filter and tablet feeder and heater. I want to convert to SWG as that is what I had/have in my other home now.
    Is there anything special I need to know about using the DE filter and this? My other pool was cartridge filters. The builder here quoted $2K for turnkey conversion which seems ridiculously high for adding an SWG so I suspect he plans to do more and wondered what it might be....hasn't explained it yet.
    thanks
    11,000 gal + overflow spa, IG gunnite, Pentair 48FNS DE filter, Hayward SP3210X15 pump, CompuPool CPSC36 Chlorine generator, pool valet w/5 zones, Pentair LP heater
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: DE filter and SWG - any issue
    Some older DE filters were Stainless rather than plastic - is that involved here or is this a fairly modern DE filter?
    I don't know of anything that is incompatible between the DE filter and the SWG.
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    Current setup
    1) 1.5 HP Whisperflow Pool Pump
    2) 48 FNS+ D.E. Pentair Filter
    3) Rainbow 300 Chlorinator
    4) heater, LP I believe
    5) pop-up pool valets
    11K gallon gunnite pool by Hamlin Pools in McAllen, TX
    I presume the $2K turnkey involves more than just the cell generator....what, I'm not sure. What in the world would that be? I 'm used to the Jandy....
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    As UWV said, no problems using DE with a swg. An appropriate sized swg (like the jandy apure1400) would run you ~$900 bucks online, so it seems the pb is charging about $1000 for the install. I would ask for details.
    Ft Lauderdale, Florida
    1,455
    One issue to keep in mind. As you backwash your filter, you're dumping out salt, so it must be replaced to maintain correct salt levels.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
