Thread: evaporation or leak
    evaporation or leak
    My neighbor had a pool and spa just completed and thinks they are losing too much water.
    The builder came and said he found a leak in the coating on the gunite base.
    he used a tool to detect for leaks and found that one.
    the pool is about 6,000G they say, but I think it's closer to 8,000.
    How much water without a cover in central florida might be normal to lose in given period of time.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: evaporation or leak
    Evaporation data by month:
    http://sewater.engr.uga.edu/evaporation/Evap_FL.php
    About 1/8" per day.
    Mark
    Thanks I'll print it for them
    Sep 2012
    Lake Nona, Florida
    386
    Thanks for that chart! I recently asked the same question and a clever person suggested a "bucket test" where you put a bucket on a step, fill it with water, and then compare loss in the bucket vs loss in the pool. I've been watching my waterline drop and thinking of finding a clean bucket in the shop... This chart would indicate I'm evaporating, not leaking though... makes me happy!
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
    mas985's Avatar
    Pleasanton, CA
    11,737
    The charts only give a rough estimate and local conditions can vary enough to double or halve the values in the chart on any given day so it is always a good idea to confirm with a bucket test.
    Mark
