Thread: Home made deck jets
    techgirl's Avatar
    Vernon, BC Canada - Pool is in Maricopa AZ (currently a holiday place)
    75
    Home made deck jets
    We have landscaping within 2 feet of the pool we're building and I was wondering what it would take to add to the irrigation system in a few years to create jets that spray into the pool?
    I guess the downside is that we'd be paying for water instead of recirculating from the pool? I like the look but also the ability to cool the pool down. If we were going to do this a few years from now should we add extra irrigation now while everything is all dug up?
    I saw some SRCC had built in another forum but thought I'd see what others have done.
    Thanks!
    Inground 12500 gallon 96 foot perimeter, 24 by 24 pool (6 by 24 of which is a "wet deck" or tanning ledge), intellibrite in spa and pool, 2 pentair LED bubblers in tanning ledge, built in table in pool, spillover spa, pebble radiance, Pentair Mastertemp 400K BTU heater, Blue Square Q360 infloor cleaner, VS2050 pump, auto leveler, Pentair easytouch 4 with wireless controller, Pentair 420 filter, custom natural gas firepit with cobalt glass.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Home made deck jets
    Hm, so you'd be spraying tap water into the pool? Not sure how well that would work; depending on how long you run the jets and what type they are, you could end up overflowing the pool pretty quickly.
    As for adding pipe now, pipe is cheap and add extras anyway! Digging later will be much more hassle.
    techgirl's Avatar
    75
    I'm not very savvy when it comes to all this plumbing - I'm not sure how the deck jets the pool builders sell get plumbed? Maybe we should have some piping put under the deck for a later date?
    I'd be concerned about adding fertilizer and chemicals to your pool. The irrigation zone would be down system from the back flow so the potential for your lawn chemicals to end up in the pool is pretty high.
    Feb 2012
    Maryland
    400
    Quote Originally Posted by techgirl
    Exactly what you need to do. Simply run a closed loop around the pool from your pad, T up at the locations you want the jets and cap them off.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
