Results 1 to 8 of 8
Thread: LED rope lights?
    techgirl's Avatar
    Vernon, BC Canada - Pool is in Maricopa AZ (currently a holiday place)
    75
    LED rope lights?
    Our pool builder doesn't recommend LED rope lights but we have a large wet deck/ tanning ledge with a table in it and I think it would look cool to have it lit up - we may not do this now but I'm wondering if we should run electrical for options later?
    Inground 12500 gallon 96 foot perimeter, 24 by 24 pool (6 by 24 of which is a "wet deck" or tanning ledge), intellibrite in spa and pool, 2 pentair LED bubblers in tanning ledge, built in table in pool, spillover spa, pebble radiance, Pentair Mastertemp 400K BTU heater, Blue Square Q360 infloor cleaner, VS2050 pump, auto leveler, Pentair easytouch 4 with wireless controller, Pentair 420 filter, custom natural gas firepit with cobalt glass.
    Re: LED rope lights?
    Unfortunately, you can't have anything like that within 10 feet (horizontally) of the water.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Is that because these are most often 120v - is this prohibited if low voltage?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yes, still not allowed, though some may tell you it should be.
    The electrical code is fairly restrictive. With only a few exceptions that don't apply here, only listed underwater light fixtures are allowed within 10 feet, regardless of voltage.
    Jun 2012
    Mint Hill, NC
    2,589
    Got it - so even if above water line they have to be rated for below water line install if within 10' - I didn't realize that.
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    techgirl,
    An (expensive) alternative is fiber optic perimeter lighting. It uses an illuminator in an electrical box that is the required distance from the pool. A covered fiber optic bundle carries the light to the pool and connects to an uncovered fiber optic that runs around the pool. Looks really cool. Safe and energy efficient, but not cheap. On my wish list. Here's a link to a typical system:
    http://www.swimmingpoolsetc.com/nexx...r-lighting.htm
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Dec 2012
    Manassas Park, VA
    207
    Here is a thread where bidDave160 used glow in the dark tiles. I think this is a great idea and would love to have something like this.
    so-it-begins-my-unconventional-build-i-m-callin-it-done-t52518.html
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
