Thread: Algae added to pool
    Dec 2012
    Melbourne, Australia
    19
    Algae added to pool
    Had to top the pool up today with some tank water, unfortunately the water probably has some algae but coming out of the tank it is quite clear. Should I shock until I pass overnight test, or would it be okay to keep FC on the higher side of okay and just keep an eye on it. Otherwise, pool is clean and sparkly.
    Thanks
    9k gallon vinyl AG
    Hurlcon 1.0 HP CX240
    Hurlcon Cartridge Filter ZX100
    22,551
    Re: Algae added to pool
    I probably wouldn't raise it to shock level, but I'd hold the FC on the high side of the racommended value and run the OCLT just to make sure you're killing everything.
    Jul 2009
    Olney, MD
    218
    FWIW, when I top off from my rain barrels, I stick the hose in the skimmer so I know that the water is going straight to my filter first. If I suspected a lot of algae, i might also turn on the inline chlorinator while I was topping off (and then turn it off as soon as I am done), or at least as Dave said, raise the chlorine level with bleach to the upper end of the range. I would do so prior to topping off. In my pool experience, proactive is always easier than reactive!
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Feb 2008
    Denton, TX
    5,061
    It's much easier to be proactive in preventing algae than it is to eliminate algae that has already taken hold.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Assuming a rain catch tank scenario - what would you do prior to loading the water into the pool - would you hit it with bleach in the tank and assume the algae is destroyed, shock it and validate it was clear with an OCLT, or would you just dump it in? Unless the tank is translucent algae can't grow so the only algae would be that of newly fallen rain. Normal rainfall events don't require shocking so is there something different about a rain tank that would make it necessary to disinfect it prior to adding to the pool?
    Jul 2009
    Olney, MD
    218
    A cup of bleach in the rainbarrel after they filled up couldn't hurt. Maybe another cupful prior to draining into the pool.
