Thread: first Pool quote MckInney TX
    Feed back desired.
    pool Spec
    Free form
    size 21 x 32
    depth 3.5' - 4.5' - 6'
    Surface area 423 sq ft
    Perimeter 92'
    Drains 2 anti vertex
    Spa
    Size 37 sq ft bi-level bench
    spa height 18"
    Spillway Multi tier
    Blower 2HP
    Fountain line included
    Drains 2 anti-vertex
    Equipment
    Pump Pentair intelliflow 3050 vs = svrs
    Filter 60 sq ft pwntair DE filter
    heater 400k BTU Pentair (NG)
    Booster Pump No
    Sanitation RB320 Automatic Chlorinator
    Cleaner Polaris 280 with 0.75 hp booster pump
    lights (1) 500W (1) 60W
    Check valve o
    Automation Pentair Wireless 4 pool Controller
    Plaster Pebble Sheen
    Coping Oklahoma, Café'
    Benches 2
    Tanning ledge Yes, 2 Gushers in tanning bed
    Deck Textured Mat single color 300sq ft
    Also Included
    32' of stone wall on beam at 12 inches tall
    11sq ft. of stone steps and veneered risers
    3' of raised pool beam at 6 inches
    40 ft of gas run to equipment
    1 additional spa light
    (3) scubbers
    repair/replace/reroute sprinklers
    repair/replace 4 pallets of damaged sod
    1 gate to code
    1 door alarm
    135' 0f 60-degree rails to bring fence to code
    umbrella/volleyball sleeves
    concrete pad for equipment
    Standard features
    plans and permits
    (2) skimmers
    Freeze guard
    pool miser automatic leveler
    Pentair never lube valves
    Overflow line
    shotcrete gunite 6200 psi
    Flood light at equipment
    Choice of tile aspotters on all steps
    all lines run and valved seperatly -2"
    Backwash line to sewer sweeps with p-trap
    tie into down spouts where needed
    deck drains where needed
    set of maintenance tools and Chemical test kit
    personal walk through
    Lifetime structural warrently
    $53,957.68
    Extras cost
    IF dig hits rock exta $295/hr after 6 hrs
    McKinney, TX
    Pool build in progress, 14.8K gallons, OK flagstone copping (sealed), IG Gunite/Pebblesheen (Blue Granite), Pentair intelliflow 3050 vs - svrs, Pentair IC20 Salt-Gen, 60 sq ft Pentair DE filter, 400k BTU Pentair (NG) heater, Polaris 280 with Booster, Dual Time Clocks with freeze protect feature, Pool (1) 500w (1) 100W Spa (1) 100w lights, (2) Skimmers, 4 Pool Returns, 6 Spa Jets, water features incl (3) 12” scuppers on 12” x 31’ raised beam, (2) Gushers on tanning ledge, and double cut spa spillway. controlled by easytouch 8
    http://www.troublefreepool.com/under...t56120-40.html
    Re: Pool quote
    That looks like a nice pool and a reasonably good price.
    I would get a larger filter. The one specced will work just fine, but a larger filter will allow you to go longer between backwashes and just slightly improve the overall efficiency of the system.
    Also, 300sq ft of deck is hardly any deck.
    Re: Pool quote
    Thaks Jason.
    WE already have a 465 sq ft patio. Plus I need a little bit of yard for the dog to do her buisness
    McKinney, TX
