Results 1 to 7 of 7
Thread: Supplies needed for a new install
    Fields's Avatar
    Jan 2013
    Columbia, SC
    43
    Hello my fellow pool lovers! I'm a newbie here. I've been reading a lot of the post here, there's a lot of useful information here!
    My new 27x52 Isle Morada AG Pool will be installed in 6 weeks! I'm so excited. I'm trying to buy everything I need now so that I won't have to run out and buy anything once the install is done. I know all of the chemiocals needed, is there any specific items i'll need? What solar blanket, testing kits, or anything else would you recommend?
    The next 6 weeks can't go by fast enough! Oh and when will you open up your pools? Thanks in advance for sharing.
    27x52 Garden Leisure AGP, Hayward Dream Line 1.5 Sand Filter, TF-100 Test kit
    BBB and Loving It!!
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Supplies needed for a new install
    You are going to need a good test kit. I use the TF 100 test kit and I also use test strips for a quick check. I must admit that I check my water daily and sometimes multiple times in a day. I also have a Taylor Speedstir for the TF 100 test kit. You are going to need a lot of supplies like liquid chlorine, borax, and baking soda. How much depends on the size of your pool as well as the location and other conditions. A lot of people here will offer advice and help you along the way. Good luck and welcome aboard! And don't forget LOTS of pool toys!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Congrats on the new pool! X2 on the TF100 kit. Become a lifetime supporter and you can get a discount on it. Look here for a solar cover http://www.solarcovers.com/shop/solar-covers. Best prices. Winter cover also. Depends where you live. Also read Pool School!!!
    Jeff
    Fields's Avatar
    Jan 2013
    Columbia, SC
    43
    Quote Originally Posted by ComputerGuyInNOLA
    Thank you!! I started buying pool toys over a year ago, lol. I can see myself checking the water multiple times a day also, at least for the first few weeks. OMG, I'm like a kid waiting on santa!
    BBB and Loving It!!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I hear Ya! You can also add your pool info in your sig. That way everybody knows what you have.
    Jeff
    30,405
    Fields,
    What will the source be for your fill water? If it is your tap water, you can test that now and that will not only give you some experience testing but tell you if you need to buy any chemistry......you may not, but you won't know until you test.
    The temptation is to run to the pool store and have them test it for you, but if you read the hundreds of posts here about pool store testing, you will find that it is usually very unreliable. Don't start off on the wrong foot.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Dittos, get the test kit and read read read pool shool (link in the upper right corner).
    One of the most important things you need from the start is knowledge, you need to know how to maintin your families pool water yourself, don't rely on someone elses knowledge because they may not have any.
    ALso, resist the temptation to buy chemical packages, you don't need to all all sorts of crazy things, the basic water strategy in pool school is all you need (assuming you have typical water).
    You should get the test kit ASAP and do some practice tests on your tap water, the first few tests may be a challenge but honestly, the repitition kicks in very fast and after a few weeks you'll have it down and by the end of summer you'll be a pro.
    The testing is far more important than the toys.
    Post some pics of the build, good luck!!
