Results 1 to 9 of 9
Thread: pvc glued and now snapped
    Frisco, TX
    11
    I am attempting to take out the strainer assembly to replace it and it seems my pvc was glued by who ever built the pool. I tried to twist it a bit and then snap! Broke at my valve and now have no idea how to get the rest off so I can replace it and put it back together. Any suggestions on how to get the pipes unstuck where they were glued?
    http://i1130.photobucket.com/albums/m53 ... 9a3723.jpg
    http://i1130.photobucket.com/albums/m53 ... dc5a75.jpg
    http://i1130.photobucket.com/albums/m53 ... c65142.jpg
    http://i1130.photobucket.com/albums/m53 ... a288b3.jpg
    13,100 Gallons IG Plaster
    Cartridge Filter (Hayward SwimClear C4020, 150 GPM)
    1.95HP Motor
    AutoClear ACL 14 SWG Chlorinator
    Hayward Phantom Pool Sweep, 3/4 hp booster pump
    38,267
    Re: pvc glued and now snapped
    You don't unglue PVC. You have to just cut out and replace it. You will have to cut back to get to straight pipe and start over.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Frisco, TX
    11
    so cut the larger piece on the outside until I can pry it off from the smaller piece? Well the part that goes on the top of pump does not have a larger piece I can cut... its just the glued piece on the inside. How do you cut the pvc thats on the inside of a bigger pipe? I cant really fit a saw in there to get it cut
    1.95HP Motor
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    I have used this tool, called a fitting saver, with mixed results. When it does work, it saves a fair amount of time. It fits on a drill motor and reams out the pipe inside a socket/fitting, leaving the fitting with a reasonably good inside surface for gluing. I would not use it in a higher pressure environment, like a water supply line. If you decided to get one, be sure to read the Amazon reviews before you use it, there are some good tips there.
    http://www.amazon.com/Pasco-3244-2-r...itting+saver+2
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    30,414
    The cut pipe protruding from your pump should be threaded. See if you can get it loose. You have nothing to lose if it's glued (I doubt it).
    The other glued joints will all have to be cut out back to clean pipe and start over. If you are not familiar with how to do that, I would hire a pool technician. They can do it pretty easily and quickly.
    Frisco, TX
    11
    I have tried to unscrew the pipes from the threaded part but they are not moving... I even drilled a hole in the pipe and put a screwdriver through it and hit it with a hammer a bit and still no movement. I think it was glued or they used some sort of pipe threading that has melted over time and turned into cement.
    1.95HP Motor
    The pipe will unscrew from the pump if you can get a good grip on it with a large plumbers wrench. It will take a fair bit of leverage, so it needs to be a solid grip. I can't tell for sure if there is enough pipe left to get a good grip on it, but there probably is.
    Much of what appears in the pictures is going to need to be replaced. There has already been a fair bit of work done in the area we can see, and in several places there isn't enough plain pipe left showing to make new connections to.
    I strongly suspect that you will be better off hiring a pool technician to do the work for you. If you don't want to go that route, you should spend some time reading up on how to do PVC plumbing before continuing.
    Fitting extenders will fit glue over the 2 in couplings
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Take the advice of others here and hire a professional that can resolve this issue for you. The time and frustration you will go thru trying to figure this out is worth hiring someone. They should know what to do and have the correct tools to do it.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
