Thread: Pump Kicks on and off
    I just installed a new Spa Pack and it is 220v, and my old pump is 115v. Currently the pump will kick on for 5 seconds and then kick off, and then repeat this process forever. I cant get the pump to run continuously. Im entirely confused, can anyone help?
    22,553
    Re: Pump Kicks on and off
    Was the wiring changed to 220 volts? If it wasn't then, there's your problem.
    Feb 2012
    Stowe, VT
    59
    Bama is correct, the 115v wiring you have uses 1 ungrounded (hot) conductor, 1 grounded (neutral) conductor, and 1 grounding (ground) conductor. Where as 220v is supplied by using 2 ungrounded conductors. When replacing a motor for a pump it is wise to get a match that is as close as possible (HP, voltage, phase, frame, etc.)
    If you continue to run the pump you will probably burn it out in a short time.
    69,000 Gal gunite indoor IG pool.
    5 HP Emerson - Pentair Triton II Commercial TR140c Sand Filter x2
    5,000 Gal gunite outdoor IG hot tub
    2 HP Sta-Rite - Pentair Triton II Commercial TR140c Sand Filter
    So the white neutral needs to be taken off and it should be good to go?
    The pump was already in place, I just replaced the Spa pack with Balboa VS500z.
    Feb 2012
    Stowe, VT
    59
    That would not work, because you still lack the second hot conductor. You'd need to have a double pole circuit breaker feeding your pump. I'd seek a professional electrician to properly feed this motor.
    22,553
    So you didn't replace the pump, you only replaced the control?
    Was your old control 110 or 220 volts?
    I have to agree with Link, it's probably time to call an electrician.
