Thread: Wall foam down under.
    Jan 2012
    Kalgoorlie - Western Australia
    27
    Hi all.
    I am currently putting together a steel panelled liner pool and I was hoping to install some wall foam to smooth everything out (imperfect panel joins and pop rivets etc). Of course finding anything like this down here is next to impossible but I have managed to find a product at Bunnings (our large hardware chain) called lamilay. It is a 2mm or 3mm thick roll of foam that comes in 10m lengths and is designed to go under floating timber floors.
    Any thoughts, alternatives, suggestions etc would be appreciated. Unfortunately I really can't find any example of the stuff online but looking at it it appears to be very robust and wouldn't tear or rip easily.
    Cheers.
    7400 gallon, IG vinyl, .75HP, Cartridge, Zodiac Chlor Perfect chlorinator. Almost finished building :)
    22,553
    Re: Wall foam down under.
    Lamilay is underlayment for laminate flooring. 3mm is about 1/8" thick so if you doubled it you'd have about the normal pool wall foam insulation thickness. Have you tried contacting a pool store that installs above ground pools? Have you tried Amazon?
    Jan 2012
    27
    Thankyou for your response.
    When I worked out what the product actually was (polyethylene foam) it was a little easier to find a supplier. I have found a company in Perth (nearby) that will cut a length and send it up. Not the cheapest option but it should work for me. I am guessing the 4mm size should be right?
    http://www.foamsales.com.au/products/cl ... foams/epe/
