Results 1 to 7 of 7
Thread: Hayward Heat Pro Fan Cuts Off - HI error
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Hi guys,
    got a heat pump and when it starts up the fan runs for like 5 seconds and then cuts off. The error is: HI
    Anyone have any idea why the fan cuts off? Everything inside seems to be ok. Had an a/c guys check it out.
    Any help is much appreciated. Thanks!
    22,542
    Re: Hayward Heat Pro Fan Cuts Off - HI error
    This is from the manual, page 17,
    3. If diagnostic code “HI” is displayed, this may indicate that an insufficient water flow condition exists. Check that the pool pump strainer basket, skimmer basket and filter are clean. After checking these items, if the “HI” indicator is still displayed, contact your original equipment installer or service provider.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks. Yes already read this. Backwashed the filter. We have good return from the jets so cant be flow.
    22,542
    Did you check the rest of the troubleshooting info? If so, it's likely a bad sensor.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    yes checked it. we use an a/c guy to repair these. on an island. no support from hayward service dept.
    I'm thinking a sensor also but the a/c guys checked that. will recheck with them. Thanks!
    22,542
    That water flow sensor is actually a pressure switch. If it's not actuating under the correct pressure that will cause that error.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks Dave. We have the a/c guys coming back today to blow out the tubes/coils..I'm guessing this pressure sensor is in the coils and could be dirty with scale. Just guessing. I don't know much about the inside of these heaters. Will let them check the pressure sensor. Thanks again.
