Results 1 to 12 of 12
Thread: Brand new pump dead after 6 weeks
    Austin, TX
    21
    Hi everyone,
    I am so frustrated. Just completed our pool install last Friday and our brand new Pentair Intelliflo variable speed pump just died after six measly weeks. Our heat pump had the pool at 90 degrees this morning and upon my return home from work this evening the temp was 65. I new something was wrong. The message displayed on the heat pump was 'low water flow' and low and behold the intelliflo was dead as a doornail. Contacted the pool builder and he said the drive must be 'messed up' and he will replace the Intelliflo tomorrow. While I appreciate that, how long will the next one last??? Went online and in a few minutes noticed that many people are having issues with these pumps. Thanks for letting me vent. My wife thanks you too.
    21K gallon IG Fiberglass pool (installed January 2013), Pentair Intelliflo VS, Pentair Clean & Clear 320, Pentair Intellichlor IC40, Pentair Ultra Temp heat pump 125K BTU, Kreepy Krawly Prowler 830, Pentair Easy Touch 8 with remote, G-Force 2 slide, TF100 test kit.
    Sep 2012
    Lake Nona, Florida
    386
    Re: Brand new pump dead after 6 weeks
    Sorry to hear about that... we just fired up our new (Jandy) pump after it sat on the pad for 2 months during the construction process. It was actually our second pump since the first one arrived with a cracked housing (though that was surely a handling issue, not a manufacturing defect). After hearing your story I'm glad we didn't let any more of the warranty lapse and I'm glad pool startup runs the pump a lot.
    I will guess that these failures follow what they call a "bathtub" curve... which means that most failures happen out-of-the box or "infant", followed by early life failures (such as yours)... then (assuming no design flaws or systemic issues) the device should run with low risk of failures during the entire service life (whatever that may be). Then at end of life the failure rate goes up again.
    How long do these pumps last in general? My pool guy gave me a bit of a shock yesterday when he said that initially Jandy (the pump he spec'd for me) had VS pump issues... but that they are all solved now. I hope he was right.
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
    22,551
    Some people have reported issues with the drives, but it's not as large a number as the internet complaints would leave you to believe. Once they replace the drive (or pump) it'll probably last many years.
    Nov 2011
    Moberly,MO
    1,010
    Second that motion Dave. Intelliflos of recent have been very reliable. But like all things electronic or computer based every once in a while you do have one drop out of life.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Austin, TX
    21
    Thank you for the responses.
    UPDATE: My pool builder just called me a few minutes ago to tell me that he has scheduled a Pentair technician to come out and take a look. And then he tells me to switch off/on the reset breaker at the panel to start the pump again!!!!! WHAT??? The pump started up. I feel like an idiot due to my ignorance of not knowing that I could have done that but is this really an issue with the drive? Would the pump still work if it was? Ugh, frustrating!
    Sep 2012
    Lake Nona, Florida
    386
    if in doubt, boot and shout!
    or
    fixed by PDPU. I'll remember that if mine ever acts up.
    22,551
    Sorry I didnt get the fact that there was no actual troubleshooting done. With all electronic equipment, the first thing to do whenever anything goes wrong is to remove power for several minutes and then repower the unit. You'd be surprised how many failures that fixes!
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Was the breaker tripped?
    Sent via Tapatalk...
    Austin, TX
    21
    Yes, the breaker tripped on the Easytouch 8 panel and it tripped again yesterday!
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Sammyw
    Maybe time to replace the breaker before trying anything else.
    Austin, TX
    21
    UnderWaterVanya you were correct. Pentair came out again and replaced the breaker. They said the incorrect breaker was used with the variable speed pump.
    Jun 2012
    Mint Hill, NC
    2,589
    Glad to hear that! That is a lot easier to deal with than something mysterious in the pump or the panel.
