Thread: Just installed liquidator - finally
    Sep 2007
    Gloucester County, NJ
    141
    I finally had a free moment to install my 8gal liquidator this morning. My equipment pad is about 1.5 feet below water level and I can get a flow rate of about 3-3.5 on the flow meter. I'm hoping this is sufficent. If it is not, what can I do to increase the flow? For what it is worth, I drilled the suction side hole on the side of my pipe just before the pump due to ease access. Would it have been better to try to drill it on the top? Also, I plan to use 12.5% chlorine in the hopes that that will offset any flow limitations I may have.
    28,000 gallon gunite/white plaster with 30ft RBB and 2ft sheer descent, 100 sq ft thermaledge, 50sq ft spa w/ 6 jets
    2HP Jandy pump, 60sq ft Jandy DE filter, 400,000 BTU Jandy LX Nat Gas Heater, 2 Jandy color lights + Jandy color spa light, Jandy Aqualink RS6, Jandy AquaPure 1400
    With 12.5% you should be fine. If there are problems they will probably only be in the very hottest weather.
    The location of the hole in the suction pipe doesn't make a significant difference.
    Sep 2007
    141
    Thanks Jason. Do you, or anyone else, happen to know what the flow rate actually represents? In other words, does 3 mean 3 gal minute or hour?
    30,431
    My thinking is it is simply a set of markings. Each individual pool will have different pressure differences across the intake/outake so the flow rate may very widely from pool to pool. I believe it to be simply reference marks for you to reset your flow.
    Sep 2007
    141
    Dave,
    Didn't think about that, but it makes sense. So, after having my Liquidator online since 10:00am this morning, my FC level increased by 2ppm to 5.5ppm according to my trusty TF-100. This was with the setting on about 3. I just lowered it a little bit since I have a feeling it is going to shoot up a bit more.....will check again tomorrow night.
    Dave - I saw that you came up with an approach to adding chlorine to the liquidator slowly from a 5gal carbouy. I'm interested in how you did that as I plan on using the same and it was very difficult to pour it in slowly and without spilling.
    30,431
    Yeah, nothing complex...I siphoned it out. I built a little plywood "stool" for my chlorine carboy...slightly taller than the water level in the liquidator.
    Turn on the pump, set the carboy up on the stool and, using tubing the same size as the liquidator uses, insert one end to the bottom of the carboy and the other end into the funnel.
    (I'm assuming you've started a siphon before so I won't get into that....I did get a little taste of the chlorine on my first careless attempt....DON'T DO THAT! )
    That's it. If you have a 4-gallon liquidator, you could make the stool a couple of inches lower than the liquidator so it would siphon 4 gallons (roughly) and stop.
