Thread: Need to cut them out and replumb
    Topic moved. Please ask questions in your own topic, instead of hijacking someone else's topic.
    quick question on a old thread, I have glued to the inside 2" to 2-1/2 inch pentair muti valves and need to cut them out and replumb, do I find 2-1/2 coupler and glue to the outside of the valve and then reduce to 2" for the pipe? IDK and hope its not a dumb question, but 40 plus a piece to replace? Any links for the part would be great.
    roth79
    13000 in ground Wet Edge Satin Tahitian Blue, Pentair VS pump, Hayward DE4820, Hayward Vac, Pentair SWG IC 40, Pentair Intellibrite 5G, Intellibrite Controller,
    TF-100 Test Kit, Seminole, West Central Florida
    38,548
    Re: Need to cut them out and replumb
    You should be able to use a 2.5"coupler on the outside of the valve and then immediately reduce back to 2" if you like.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Sorry I thought the thread was closed as it was pretty old, I assumed he got his answer, but it wont happen again, sorry. I cant find 2-1/2 couplings at the depot,Thanks JB
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yeah, you'll have to go to a real plumbing store to get them.
