Thread: Recommendations on raising pool floor
    Jul 2012
    Colleyville, TX
    20
    We have a +/- 17,000 gallon pool that has a deep end depth of about 7 feet. I really want a pool that can be fully utilized, so as part of our remodel we are having the PB's bid to raise the floor and create a play pool. I've talked to four companies so far and the recommendations are split 50/50 on this process. Two say it needs to be filled with gunite, two say concrete. It seems that this type of remodel is fairly rare, but all of the builders say they have done it at least a few times.
    So, does anyone have recommendations on which material needs to be used? Any risks of going with concrete and rebar? Is using gunite a must? We want our remodel done right, so I'm hoping I can open up this discussion and get some help from you guys as we decide on a company to complete the job.
    Thanks
    +/- 17,000 gallon IG gunite pool & spa; Mini pebble; Oklahoma flagstone; Water feature; Pentair catridge filter; Pentair MiniMax 75 heater (replacing in the future, too small); Dolphin DX4 Robotic cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Recommendations on raising pool floor
    Gunite is concrete. It differs in the way it is applied, but it is the same stuff.
    Jul 2012
    Colleyville, TX
    20
    I understand gunite is concrete with subtle differences between the two. Since I currently have a gunite pool, is it mandatory that I use gunite or will standard concrete work? Maybe I'm over thinking this, just make sure it is done the right way. I don't want to have any issues in the future with the new joints in my pool floor.
    Aug 2007
    near the swamp
    806
    I'm pretty sure cold joints don't exist with gunite.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by ctaylor81
    This may be oversimplified but here's an explanation of Gunite vs. Concrete:
    http://www.ehow.com/info_12138295_gunit ... crete.html
    This may be better:
    http://en.wikipedia.org/wiki/Shotcrete
    Scroll down to the section on Shotecrete vs. Gunite if you want to get the details.
