Thread: Need help identifying pool
    Hi, I just bought a used above ground pool. I don't know the name of the pool or the manufacturer. This is what I do know.... It's 24' round 52" pool with resin rails. I've searched the Internet trying to find any pools that have the same type of rails but I haven't found any. I need to buy the bottom track. I'm including a pic of the top rail and caps. Any help would be most appreciated!
    Oct 2012
    209
    Re: Need help identifying pool
    You can have some fabricated at a local machine shop. But as far as trying to track the parts down, it will be difficult without knowing the manufacturer. With any luck you might find someone that has the same pool, or find some compatable parts. I myself have never seen a pool that looks the same as that one.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Shavone1
    That looks identical to mine although mine is a 48" wall. It is a Aqualeader (model Sentinelle I think)....Aqualeader is now owned by Wilbar group.
    Thank you linen! I will follow up on the info you provided!
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    +1 on the Aqua Leader
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
