Thread: New Build in Sacramento, CA area
    Hello, I'm hoping to get feedback on equipment, plumbing, floor depths for a planned new build. I've read a lot of great posts here, and as a first-timer for a pool, I'm hoping to learn from the experience represented here. I realize a pic would help with the description, I will try to get a design pic added.
    Pool:
    * ~800 sqft free-form salt pool, and 8' diameter spa with 8 jets and spill into pool
    * 3' - (4' - 4.5' for ~25' stretch) - 5' - 7'
    * somewhat peanut-shaped, with 14' width at midpoint
    * 13' x 10' carribean shelf, 18" deep w/umbrella sleeve
    * Good size waterfall from natural raised rock outcropping, 3 spills into pool
    * ~50 lin.ft of Sierra Boulder on notched beam, matching with natural backdrop
    Trying to design multi-function pool, with the 4 - 4.5' stretch intended for volleyball use without adding another valley to pool floor. Not ideal for that use, but hoping it would work well while keeping free-form and general use.
    Equipment:
    # Intelli-Pro 4x160 var speed filter/waterfall pump
    # Sta-Rite 450 sqft Cartridge filter (S8M150? I'm not sure)
    # Sta-Rite Max-E-Pro 2HP spa jet pump
    # Pentair Legend Platinum Pool Cleaner, with Sta-Rite 3/4HP booster pump
    # Sta-Rite Max-E-Therm 400,000 BTU heater
    # IntelliChlor IC40 SWG
    # Pentair Easytouch Control System
    Plumbing:
    * 1 U-3 Skimmer
    * 2" main drain and skimmer suctions, and returns
    * 1.5" pool sweep line
    * 1" overflow
    * auto-fill
    * 2" spa drain suctions & return
    * 2.5" spa jet suctions & returns
    * 1.5" spa airline
    * 3" waterfall suctions & returns
    Some of the posts I've read, have me concerned a bit in the plumbing area, and I'm not very knowledgable in that area.
    Thank you for your feedback.
    Feb 2008
    Denton, TX
    5,061
    Re: New Build in Sacramento, CA area
    Welcome to TFP! Sounds like a nice setup. Look forward to seeing the images.
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Sounds like a great set-up neighbor! Which builder did you go with? Also have you considered lights at all?
